BrettZZR wrote:Before you go to too much trouble, test the volts on the battery and while testing turn the ignition ON, and see what happens to the voltage. My prime suspect from your description is still a dud battery. (They get a hairline crack inside that allows normal voltage, until you want to use it!
(-8
ZX_Menace wrote:BrettZZR wrote:Before you go to too much trouble, test the volts on the battery and while testing turn the ignition ON, and see what happens to the voltage. My prime suspect from your description is still a dud battery. (They get a hairline crack inside that allows normal voltage, until you want to use it!
(-8
actually, thinking on that more, will that test work considering when i turn the key im getting no ignition lights at all....therefore it wont be drawing any power. would i be better off taking the battery into a battery shop to get it tested?
ZX_Menace wrote:... tested it last night, no change in voltage when turning the ignition on ...
ZX_Menace wrote:haha, thanks mate, didn't get a chance to look at the bike on the weekend, hopefully i find some time this week, going to pull the ignition barrel apart and have a crack at fixing it, otherwise ill be ordering a new one
lunatick wrote:ZX_Menace wrote:haha, thanks mate, didn't get a chance to look at the bike on the weekend, hopefully i find some time this week, going to pull the ignition barrel apart and have a crack at fixing it, otherwise ill be ordering a new one
My L3 ZXR did the same thing
And it was the contacts in the ignition barrel
Mitch wrote:looking at the parts fiche the ZX7R ignition barrel is specific to that model only.
http://www.partsfish.com/oemparts/p/kawasaki/27005-1199/switch-assy-ignition
have you called up any bike wreckers?
Not that it matters but the 9R, 6R, and ZZR6 all share the same part
(-8
Return to Introductions and Newbie Zone
Users browsing this forum: No registered users and 22 guests
