1991 ZX750 acceleration problems
Postby georgeshtc » Tue Nov 02, 2010 8:10 pm
Hi guys I am new to all this so thanks in advance :D
I got myself a 1991 zx750 and i am experiencing a shuddering/retarding on heavy acceleration (half throttle throught to full throttle)
I have pulled the tank off and noticed no air box and having done some googling i am coming to a conclusion that it is a MUST for this model to have a air box.
Is this true? is there a way around this problem?
any advice to fix this problem would be appreciated even any leads into getting a airbox would be good :D
i can post some pics if required...
thanks george
georgeshtc
Bike: ZXR750
Re: 1991 ZX750 acceleration problems
Postby Gosling1 » Tue Nov 02, 2010 8:14 pm
georgeshtc wrote:......I have pulled the tank off and noticed no air box and having done some googling i am coming to a conclusion that it is a MUST for this model to have a air box.
any advice to fix this problem would be appreciated even any leads into getting a airbox would be good :D......
Yes - you must have an airbox. You also must have all the proper hoses hooked up to the airbox so that the carbs are pressurised correctly. The way around this problem is to fit an airbox with all the OEM hoses.
Try Findapart for checking the wreckers out there for an OEM airbox and all the bits you need.
Postby Tack » Tue Nov 02, 2010 10:08 pm
where abouts are you in queensland?
Tack
Postby georgeshtc » Wed Nov 03, 2010 5:18 pm
Thanks for that reassuarance on that....
i am in forest lake qld just near logan/ipswich/centenary hwy.
any good wreckers nearby?? google is telling my that the closest is in the gold coast@!
georgeshtc
Bike: ZXR750
Postby Tack » Wed Nov 03, 2010 6:13 pm
I might have one....I'll have a look....only cost (if you pick it up) will be a donation to KSRC :D
Tack
Postby georgeshtc » Wed Nov 03, 2010 9:35 pm
sweet! ill pick up or pay for postage :D and dont know how but ill make a donation to KSRC
georgeshtc
Bike: ZXR750
Postby georgeshtc » Sat Nov 06, 2010 7:40 pm
The Air box fixed it right up! :D
Even the little insert at the rear of the airbox makes a difference (6000rpm/8000rpm hesitates like crazy) and must be kept in..
thank you very much!
who was the moderator again for the donation?
AND A BIG THANK YOU AGAIN BRETT (TACK) YOU ARE A LEGEND! YOU SAVED ME THE BIGGEST HEADAKE AND A LOT OF CASH :kuda:
georgeshtc
Bike: ZXR750
Postby Tack » Sat Nov 06, 2010 8:11 pm
Glad it worked
madkaw...ownes the site
Tack
Return to ZX-R Older Model Discussion
Users browsing this forum: No registered users and 3 guests
cron
