Bolt on mufflers are they all the same?
Postby Stumbows » Wed Jun 30, 2010 12:50 am
I've not got a ZX7R and am looking to replace the stock muffler system with a bolt on but I'm having trouble hunting down some good deals on the internet... I used to have a ZRX1200 '08 model which also had a bolt on to which I fitted a scorpion system and as far as I can see they are both of the same type 3 bolt setup.. Are they the same spacing? I've heard that other models of the kwaka are with the 7R but just not sure which ones because if I can find out it might broaden my scope on possible pipes to buy.
Stumbows
Re: Bolt on mufflers are they all the same?
Postby greenmeanie » Wed Jun 30, 2010 5:08 pm
Glenn
2009 ZX10R
greenmeanie
Postby hoffy » Wed Jun 30, 2010 5:59 pm
No, they are all different as they have different mounting points...the bit that attaches to the footpeg bracket to hold it in place..
Postby TimMc » Thu Jul 01, 2010 12:55 pm
hoffy V2.0 wrote:No, they are all different as they have different mounting points...the bit that attaches to the footpeg bracket to hold it in place..
If that's the only difference, then bolt ons like my 9er's Kerker might fit. They have an adjustable bracket that wraps around the muffler and can slide up, down or around. If this bracket/strap didn't fit, it would be pretty easy to make up another.
TimMc
Postby hoffy » Thu Jul 01, 2010 6:42 pm
they mostly all have different stud patterns also..
It is quite easy to find stock pipes on ebay as many change to aftermarket pipes and have stockers left around..
Postby mike-s » Fri Jul 02, 2010 10:59 pm
I know that for bolt-on mufflers, a lot of bikes may have the same stud pattern. i.e. i bought a muffler via this forum that was marked as being for a mid-late 90's zx6-r. The bolt pattern and mounting dimensions for the end of the muffler fitted my rf900. On the same note my RF900 was reputed to have a muffler that was interchangeable with the bandit's of the era, etc..
Return to ZX-R Older Model Discussion
cron
