Converting to a keyless ignition
Postby dave#3 » Fri May 30, 2008 7:31 pm
'The Mutant' has a veritable shitload of wiring left on it - I'm stripping out what I don't need (more to save hassle troubleshooting things in the future than to save weight or space). After seeing Matt's new tracky with the keyless ignition I got to thinking and decided I wanted to do it to mine too (if for no other reason that 'cause it looks cool :)).
Anyone done this? Any hints? I'm pretty good with electrickery, so I can probably work it out, but if you've done it I'd be happy to learn from your mistakes :)
BTW, for those that don't know, 'the Mutant' is a 95 (L3) zxr750 with a B series zx9r engine in it.
Also, do you need a traditional kill switch to race in NE2? If not, I can probably do away with the right-hand switch block as well as the left.
http://www.oz4x4.net/gallery2
dave#3
Re: Converting to a keyless ignition
Postby robracer » Fri May 30, 2008 7:36 pm
dave#3 wrote:Also, do you need a traditional kill switch to race in NE2? If not, I can probably do away with the right-hand switch block as well as the left.
No dave, but would suggest a lanyard cut off
Postby dave#3 » Fri May 30, 2008 7:42 pm
That's what I was thinking.
dave#3
Postby MadKaw » Fri May 30, 2008 7:43 pm
If you asked this a month ago, I could have shown you... :-)
Postby dave#3 » Fri May 30, 2008 7:45 pm
MadKaw wrote:If you asked this a month ago, I could have shown you... :-)
I've never been known for my timing :oops: Any hints????
dave#3
Postby MadKaw » Fri May 30, 2008 7:57 pm
yep, you need a switch and a button... :-)
Thats the best I can do atm... We rewired mine that many times you'd think I'd remember every single strand... I do, but only in my nightmares.. :shock:
Franks 9 has been stripped, have at look at that for ideas... it'll be at the creek tomorrow.. and then at my place, again...
Return to ZX-R Older Model Discussion
