Thu Mar 06, 2014 12:30 pm
Took me a while to organise a helper and get some time to do it but the engine is finally back in the bike. Now all i have to do is everything!
Mon Mar 10, 2014 8:31 am
spent all weekend putting the bike back together ( I had to tear down the gearbox again because one of the selector forks was in wrong and I couldn't get gears 2-6 hahah). Once it was together I didn't have any spare bolts or electrical leads. However it makes a weird noise when I try to start it :S it sounds like something is hitting even though its in neutral. I have a feeling that the problem is in the clutch (which doesn't make sense I know)
Mon Mar 10, 2014 8:32 am
Also, funny story. When I put a piece of wood through the back wheel to tighten the clutch I forgot about the valve on the tire. You can guess what happened next...
Mon Mar 17, 2014 6:34 pm
Bought a new clutch cable as the old was adjusted to the end and wasn't able to fully disengage the clutch. Hopefully problem solved.
Tue Mar 18, 2014 9:09 pm
Its alive!
Wed Mar 19, 2014 8:01 am
good work
Wed Mar 19, 2014 8:42 pm
Ill try and upload a video, in the mean time heres a pic (the lights only come on after the engine has started).
Wed Mar 19, 2014 8:51 pm
not sure if this will work or not. I tried uploading the video to photobucket...
http://s881.photobucket.com/user/bjn...b6666.mp4.html
Thu Mar 20, 2014 8:07 am
bjn_42 wrote:not sure if this will work or not. I tried uploading the video to photobucket...
Nope, but congratulations, well done on the repair!
Thu Mar 27, 2014 12:56 pm
Replaced all the gaskets and have torque the clutch springs to ~8.8Nm with a small torque wrench that i bought especially for that job (and also because i came with a set of hex head socket bits).
Also changed the oil and filter. Mechanic did that thing where they tighten the oil filter too much so I had to put a screw driver through it to unscrew it. The oil is so new its clearer than the sight glass.
Cant wait for the new clutch cable to arrive so i can ride
Mon Mar 31, 2014 9:03 pm
I was expecting my new clutch cable on Friday just gone. The tracking details updated to this "Expected delivery on or about 04/06/2014".
Thu Apr 03, 2014 12:28 pm
So I went for my first test rid last night and everything went well.
Rode to work this morning and it is even better!
I dont remember the last time i grinned so much
