Post a reply
Re: 1990 ZXR750H2 Period 6 Formula 750 race build.
Mon Feb 17, 2014 6:54 pm
Some more progress has been made.
I've started to mock up to see what I can get to fit, have to make, etc.
Mon Feb 17, 2014 7:52 pm
its all looking good Andrew the rear sets are nice and simple they way it should be . I see the motor seems to be missing out put shaft and the like I take it she is awaiting her parts . TOP JOB
Fri Mar 21, 2014 3:20 pm
After a number of attempts and redesigns, I've pretty much settled on this.
Anybody happen to know where I can buy a gear shift rod approx. 350mm long?
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/Rearsets_FinalAssembly_zps57a17ea0.jpg.html"]Image[/url]
Mon Mar 24, 2014 7:26 am
The 'shark fin'.
Tue Mar 25, 2014 9:55 am
Looking great!
Tue Mar 25, 2014 7:32 pm
good work Andrew
Tue Mar 25, 2014 8:29 pm
re the shark fin, have you thought about designing it to use the swing arm rear stand bobbin mount instead of drilling into the swing arm? i remember buying one like that for my old ZX6R, just bolted straight on.
BTW great work
Thu Mar 27, 2014 8:15 am
Mitch wrote:re the shark fin, have you thought about designing it to use the swing arm rear stand bobbin mount instead of drilling into the swing arm?
I did think about it and have plans to draw up something along those lines.
For the moment, I'm going with this as a couple of mates want them and, they're all different bikes.
Tue Apr 01, 2014 12:38 pm
Slowly but surely, she's getting there :)
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/FrontRight_zps4ac5f6cd.jpg.html"]Image[/url]
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/FrontLeft_zpsef12aada.jpg.html"]Image[/url]
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/RearLeft_zpsfd3a0d03.jpg.html"]Image[/url]
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/RearRight_zps1f79f252.jpg.html"]Image[/url]
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/DashTop_zpsd3baa708.jpg.html"]Image[/url]
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/Dash_zps206bd171.jpg.html"]Image[/url]
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/RearSetRight_zpsba67bdfc.jpg.html"]Image[/url]
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/RearSetLeft_zps253657d7.jpg.html"]Image[/url]
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/SharkFinMWR_zps29eaaff5.jpg.html"]Image[/url]
Thu Apr 03, 2014 9:15 am
Getting the dash water cut instead of my 'home brand' effort. ;)
Thu Apr 03, 2014 3:33 pm
Andrew you never seem to stop mate
Thu Apr 03, 2014 6:06 pm
captain slow wrote:Andrew you never seem to stop mate
You'd be surprised how easy it is to stop me. ;)
I've tried to PM you but, it just stays in the 'Outbox'.
Is your 'Inbox' full?
Mon Apr 07, 2014 5:55 pm
I'm trying to decide on which of the following bracket designs to fabricate for the steering damper fork clamp.
So, KSRC brains trust, what do you think, A, B or C?
[url="http://s1050.photobucket.com/user/19andrew59/media/1990%20ZXR750%20H2/SteeringDamperBracketOptions_zpsab735c77.jpg.html"]Image[/url]
Mon Apr 07, 2014 9:03 pm
B or C will be easier to take off and put on. There's nothing worse than fitting up a set of forks and then realising you have to pull one back out because you forgot the damper mount. :oops:
Wed Apr 09, 2014 5:10 pm
IMO, B will have a moment applied equally across the 2 bolts, whereas C will have a much larger moment applied at the further bolt, which will mean that your bracket will have to be overengineered on the mount side to compensate for the different strength required on the other side.
Though C may be easier to mount and dismount...
Post a reply
