Switch to full style
Post a reply
ZX7R Sprockets
Sat Jun 26, 2010 4:41 am
Guys I'm looking to buy some sprockets online as I'm sick of dealing with my local shop and I can probably find a better deal online anyway. I have a 97' model ZX7R with a 520 conversion but I need a new front and rear sprocket.. I know how many teeth I need I just don't know if there is a particular stud pattern for them or something? Will any 520 Sprocket fit the bike or what should I be looking for if a bike model isn't mentioned?
Re: ZX7R Sprockets
Sat Jun 26, 2010 7:47 am
Welcome to KSRC wave.gif sounds like vortex sprockets might be the go or steel ones would be cheaper, I would suggest MCAS & if they don't have any they can order them in....... savings on line would not be much & you risk getting the wrong pattern as there are quite a few different ones. MCAS would have catalogs with the conversion details to work out the most suitable.
Re: ZX7R Sprockets
Sat Jun 26, 2010 1:34 pm
Also try Superbike Supply, one of the site sponsors. I have always found Tim easy to deal with and pricing is good.
Re: ZX7R Sprockets
Tue Jun 29, 2010 2:32 am
Guys thanks for your replies... Called one of my localish dealers and found they had the 520 kit of sprockets in stock for my ZX, so I went in and picked them up and when I got home realised they were about 2/3rds the thickness of the current ones :? not knowing what had happened I took my sprocket in (the original) and showed them.. they couldn't figure out what it was as it was thicker than 520, 525 and 530 so again :? dunno. Any I decided to buy a new chain to suit as well because I've only had the bike a week and although I was told it was only replaced 1000kms ago I have my suspicions it was not good because it had never been lubed in 6months/1000kms and there were a lot of other neglected parts of the bike like hot tyre pressure (had to test as soon as i got home) 15psi front and 25psi rear hahaha.... So long story short it really does have a 520 conversion now and brand new front and rear sprockts with an RK Gold chain.
Post a reply
