Front sprockets
Front sprockets
Postby Awesome » Sat Mar 31, 2012 4:57 pm
Hey guys I want to go to a 16 tooth front sprocket have all the gear but the nut is very tight. Just checkin is it left hand or right hand thread?
Cheers Rob Cairns
Awesome
Re: Front sprockets
Postby Blurr » Sat Mar 31, 2012 5:20 pm
you'll need a rattle gun or a big fark off breaker bar to get it off. They all come out of Kawa Japan like that.
Best bet if you dont have access to either, is go to a tyre shop and get them to take it off for you.
In either case make sure a single hex nut is used.
Oh and it is standard thread
Re: Front sprockets
Postby Phil » Sat Mar 31, 2012 7:55 pm
Yep, what Russ said. If you go to a shop to get it done you can then just do it up a little (I shit you not) and bend the washer dodadthingy back over to go home and then take it off, thats what I have done on a few occasions. No need to tighten the fuck out of it when you do it up, either, that washer bent over will do that ;)
Re: Front sprockets
Postby Awesome » Sat Mar 31, 2012 8:21 pm
Thanks Guys
Awesome
Re: Front sprockets
Postby Awesome » Wed May 09, 2012 6:56 pm
Goes much better now ;-)
Awesome
Front sprockets
Postby Blurr » Wed May 09, 2012 7:46 pm
Good to hear.
It is a must do mod for most modern roadies if you ask me.
Users browsing this forum: Google [Bot] and 6 guests
cron
