Z750 rear shock options
Postby Lurch » Sat Oct 08, 2011 1:48 pm
Hey all.
So I got out this morning for a decent fang on the new Zed. Lottsa fun, however the suspension is WAY too stiff.
Not sure what I'll do about the front yet, however for the rear I'm looking for options.
From the reading I've done, the best shock for this bike is the rear shock from a 2003 (BH1 ?) ZX636?
Has anyone here done this mod? Whats it like to ride with this shock?
Lurch
Lurch
Bike: GPz750
Postby Wattie » Sat Oct 08, 2011 2:25 pm
You are the 1st person to ever complain of a stock z being too stiff!
Re: Z750 rear shock options
Postby Lurch » Sat Oct 08, 2011 5:06 pm
Actually I did just go out and found the pre-load on the rear was wound all the way up.
I've now wound it all the way down and will adjust from there.
I should point out that the front at least isn't stock. It's had (unknown) work done to suit the previous owner.
Lurch
Bike: GPz750
Postby dub » Sat Oct 08, 2011 6:02 pm
What do you weigh? About 85kg??
I've no idea what the stock spring is but your z750 weighs the same as my z1000 and that has (OEM) a 10.5 kg spring in the back with only preload adjustability.
If you want a softer shock, the 08/09 zx10r shock spring was 9.1kg. If you want to go softer again, have a look at the 06/07 zx10 shock, they had a 8.3kg spring (although, even with your skinny arse I reckon that would be too soft). I went the 04/05 zx10r shock on my z1000 as that was a 10kg spring and was a much better quality piece of kit. I think the more recent 6's had 9.7kg (my memory gets hazy about the 6's as I really only looked at the 10's).
BTW, I think it's worth a call to the old owner to find out the work that had/had not been done to the existing suspension. It would be good to know what your are starting with.
2004 Z1000
1982 GPz750
dub
Postby Gosling1 » Sat Oct 08, 2011 7:51 pm
Wattie wrote:.....You are the 1st person to ever complain of a stock z being too stiff!.....
previous owner was a portly gent, maybe 40+ kegs heavier than Lurch? had everything wound up to buggery.....
Postby Lurch » Sat Oct 08, 2011 8:20 pm
Went on a tag run* this evening with the pre-load wound right down - much better.
*Tag is a game we play on CR.
Lurch
Bike: GPz750
Users browsing this forum: No registered users and 3 guests
