Zed's Rearsets
Zed's Rearsets
Postby 67-FKD » Sun Dec 07, 2008 5:39 pm
Hey guys, does anyone know if these are painted, or jsut normal alloy, after washign my bike today it appears there is a small crack going down the folds of the metal.
Is it somethign to be concerned about? and is a replacement easy enough to find?
67-FKD
Re: Zed's Rearsets
Postby robracer » Sun Dec 07, 2008 5:51 pm
Its Cast alloy.....there are bound to be imperfections ;)
Re: Zed's Rearsets
Postby 67-FKD » Sun Dec 07, 2008 6:08 pm
67-FKD
Re: Zed's Rearsets
Postby Saki » Sun Dec 07, 2008 7:25 pm
Nope, nothing painted on the rear sets. Ouch if they have a crack, might be time to replace!
Saki
Re: Zed's Rearsets
Postby robracer » Sun Dec 07, 2008 7:35 pm
Think I can make out the crack ..... does it open when pressure is applied to the footrest? if so it will need to go :?
If it is cracked METROS have wrecked one that I know of ;)
http://www.motorcyclewreckers.com/index.html
Suggest do the ring around interstate as being a small part the freight from a wrecker will be cheap &
you can probly still use the existing rearset, but carefully....... now that you know there is a problem.
Re: Zed's Rearsets
Postby 67-FKD » Sun Dec 07, 2008 8:04 pm
the crack doesnt seem to open under pressure, but ill be keeping an eye on it, thanks for the heads up rob
67-FKD
Re: Zed's Rearsets
Postby Nelso » Tue Dec 09, 2008 10:42 pm
Does anyone know of any aftermarket rearsets that will fit a Z?
Nelso
Re: Zed's Rearsets
Postby 67-FKD » Wed Dec 10, 2008 8:10 pm
that was my next question...
67-FKD
