Vibration / Rattle on the Rex !! HELP !!
Postby Blue14 » Wed Mar 04, 2009 9:15 pm
Hey people, the ZRX has an annoying vibrating / rattle sound coming up from front of bike somewhere at around 3.5 - 4k in the rev range. I have checked everything i possibly can. Anybody had this problem or heard of anyone with this problem.
Its driving me nuts and i have to fix it.. :evil:
Thanks, Paul. :D
Blue14
Re: Vibration / Rattle on the Rex !! HELP !!
Postby TopCat » Wed Mar 04, 2009 9:38 pm
is it coming from the bikini fairing. put a strip of tape where the inner piece joins to the fairing at each side.
see if this fixes the problem
TC
TopCat
73% of internet statistics are made up on the spot
TopCat
Postby mick_dundee » Thu Mar 05, 2009 5:52 am
I had that recently on the 9, turned out the mob that did my fork seals forogt to tighten the bolts on the lower triple clamp... not happy Jan!
Postby J.B » Thu Mar 05, 2009 7:33 am
Had a very similar rattle on my rex just last weekend, but only occured for a very limited rpm range ie 4000 +/- 50 rpm. Turned out to be the speedo cable retaining nut on the back of the cluster. Only figured that one out when the speedo dropped out on the way home from our ride on the weekend :roll:
J.B
Postby matchan » Thu Mar 05, 2009 7:51 am
can also get an annoying buzz from the dash if the rear cover of the instrument cluster is slightly lose
matchan
Postby Blue14 » Thu Mar 05, 2009 11:53 am
will check out these possibilties...
Keep em coming guys, much appreciated..
Blue14
Postby Woof » Thu Mar 05, 2009 4:34 pm
Mate, start at the bottom of the fork legs and work your way up. I had a buzz at 2900-3200 like TC above and it was the fairing inner rubbing the inside of the fairing. A clean and reassemly with a tiny bit of black silastic fixed it. :!: hello2.gif Ooh, Ooh, also, at higher revs, the radiator shroud-mounts can buzz and it sound like its coming from the front. I took the four small washer-spacers out (the ones that line the rubber grommets) and shortened them by about 0.5 mill or so and screwed them back in with a little vaseline to help the neoprene out: buzz gone! :kuda:
Woof
Postby Blue14 » Sat Mar 07, 2009 10:59 pm
Ok have checked from top to bottom. I think it maybe the speedo head ?? It seemed to have almost gone until i touched the knob that you use to reset the trip metre.. Maybe its lose in there or something, any ideas ??
Blue14
Postby jonoZRX » Sun Mar 08, 2009 1:02 am
Blue14 wrote:Hey people, the ZRX has an annoying vibrating / rattle sound coming up from front of bike somewhere at around 3.5 - 4k in the rev range
Mine does the exact same thing and I've never been able to find what causes it.
Hope that helps :lol:
jonoZRX
Postby Peter » Mon Mar 09, 2009 5:34 pm
It could be the keys in your pocket ??
Peter
Postby Strika » Mon Mar 09, 2009 7:59 pm
You big prick! You only come in here to get your problems fixed! You never contribute anymore! So obviously we are just a resource for you now! Plus...you don't return phone calls! You're obviously too busy with ya netnanny buddies to worry about us lot now! So why don't ya go and get a big black one up ya!
Postby Peter » Tue Mar 10, 2009 4:50 pm
Huh ?? Thanks for the big prick complement ;) and doesn't everyone come here to get their kawasaki problems fixed :roll: you do realise it is a bike forum don't you :oops: and I have offered plenty of advice :kuda: and I don't have any netnanny buddies :cry: and what phone call was I supposed to have answered :shock: and getting a big black one up me is a bit racist isn't it ?? Lucky for you I've got a sense of humor or I could have taken you seriously and written something courageous and scary and threatening.
Peter
Postby Peter » Tue Mar 10, 2009 5:10 pm
Oh yeah blue 14,try the screen on the bikini fairing, mine used to vibrate at about 4000 revs so I locktited the screws and it has never come loose again. Don't use a permanent locktight.
Peter
Postby scottyZRX » Tue Mar 10, 2009 5:46 pm
My rattle is around the radiator.
When I reach down & hold it it stops.
My new can has arrived so I will be having a working bee in the shed during the week.
Fix rattle, fit can & chop rear guard.... :D
scottyZRX
Postby scottyZRX » Thu Mar 12, 2009 5:59 pm
I took the four small washer-spacers out (the ones that line the rubber grommets) and shortened them by about 0.5 mill or so and screwed them back in with a little vaseline to help the neoprene out: buzz gone! :kuda:[/quote]
I second this motion...
I just did the same & it fixed it a treat.
scottyZRX
Next
Users browsing this forum: No registered users and 3 guests
