Richo wrote:Ill throw in my 2cents worth here and say that to shave off some speed while cornering you should be using the rear brake, not the front ... Someone correct me if Im wrong yeah? ...
Head_Mechanic wrote: BUT if you have to brake use the back brake and hold it on as you power out of the corner.
Yup is that before the self presevation kicks in? Personally If I am hitting a corner harder than usual... by That point using the front brakes would be a joke, just lean the farker & ride the corner...... it would be so easy to squeeze too hard & go down like the titanicPeter wrote: If you guys haven't ever had to use a bit of front brake in a corner then you've just got to ride a little harder, lol.
