Z1-R Engine re-repaint
Postby slimey » Mon Nov 09, 2015 9:06 am
Finally managed to get some paint on my Z1-R engine over the weekend.
Previous attempt was a pretty inconsistent and crappy mess so had to rub/scrub the affected parts back (again!)
Anyway got a chain block and some threaded rod and made up a lifting and supporting rig for the job.
Hoisted up the engine, washed it and blew off any dust/moisture.
Masked off the parts not to be painted and checked temp - about 20degC and not too humid.
Applied the VHT engine enamel (satin black) per the instructions and was very excited to watch the paint dry -
came out pretty good, a huge improvement on the previous fuckup!
Covers to be polished and new RH points cover 2b fitted
Current Project
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
slimey
Re: Z1-R Engine re-repaint
Postby slimey » Mon Nov 09, 2015 9:15 am
another pic of the re repaint job
Current Project
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
slimey
Postby slimey » Mon Nov 09, 2015 9:17 am
One more....
Current Project
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
slimey
Postby slimey » Mon Nov 09, 2015 9:19 am
Last one ....
Current Project
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
slimey
Postby BrettZZR » Mon Nov 09, 2015 4:03 pm
Looks the biz!
(-8
BrettZZR
Bike: ZZR1100
Postby kawadave » Mon Nov 09, 2015 7:20 pm
Excellent Mr slime. :kuda:
If you have a hot gun it wouldn't hurt to give a hit to help the paint cure and harden.
2013 Motogp tipping champ.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
kawadave
Postby slimey » Tue Nov 10, 2015 6:55 am
Ok Dave - not a bad idea - I'll see if I can get onto that this weekend!
Current Project
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
slimey
Postby JimZXR » Tue Nov 10, 2015 4:54 pm
Great job, what did you clean the engine down with before hand?
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
JimZXR
Bike: ZXR750
Postby slimey » Wed Nov 11, 2015 7:32 am
G'day Jim,
Just a very mild soap solution - few drops dishwashing liquid in a bucket of water.
Then wiped down with a clean rag, blew it all dry, masked it up and applied paint straight away before any dust had a chance to settle onto clean surfaces.
Applied several coats - VHT spec calls for 10 mins between coats (with all coats to be applied within 1 hour)
10 mins was about how long it took to go right over/under/around the engine so timing worked out ok.
Very fiddly around the top head fins - needed to attack from all angles to get full coverage.
Used one whole can on the engine, so now have a spare can for touch-ups once the engine is fitted.
(Also have a nicely painted section of chain - hehehehe) :cheesy:
Current Project
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
slimey
Postby Gosling1 » Tue Apr 26, 2016 8:21 pm
engine looks great :kuda:
Postby pkay » Wed Apr 27, 2016 12:24 pm
Wish I could do that..............................
Save me shitloads if I did!
PK
pkay
Bike: ZXR750
Postby slimey » Thu Apr 28, 2016 1:40 pm
Give it a crack - I'm no paint guru and if I can do it so can you!
Just need to make sure surfaces are clean, free of grease/oil/flaky paint/dust etc
and put lots of thin coats on rather than a few thick ones.
Current Project
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
slimey
Return to Classic Kawi Discussion
