The IC unit on a 1983 GPZ1100 should have 9 wires in total - 4 coming in and 5 going out. The colour coding is as follows:
Black/Blue/Yellow/Red - these are the input wires from the pick-up coils at the end of the crank. They should go to a small 4-pin plug connector which matches the 4-pin plug connector from the pick-up coils.
The other 4 wires are black/yellow trace - this is the earth wire for the IC unit. Red wire - this is the +12v input for the IC unit. Normally this +12v input is switched directly from the +12v side of the ignition coils (i.e. powered by ignition and kill switch).
The last 2 wires are black and green - these are the signal wires that connect to the ignition coils under the tank. Black to left coil, green to right.
There should be one additional wire - black/yellow trace - this is just an additional earth for the IC unit. That would give you 9 wires coming out of the IC unit.
Hope that helps
