fornt forks
All GPx and GPz Models
fornt forks
Postby camit0434 » Mon Mar 09, 2009 8:54 pm
how do u remove the damper rod seat,mine is still in the stachion,does it tap out or screw out,signed not sure.gpz 750 85 model.
camit0434
Bike: GPz750
Re: fornt forks
Postby seiko1 » Mon Mar 09, 2009 9:51 pm
f o r n t forks??? :lol:
hehehehehe
Re: fornt forks
Postby mike-s » Mon Mar 09, 2009 10:06 pm
i read typo so well that i didn't even notice!
Re: fornt forks
Postby Strika » Tue Mar 10, 2009 6:55 am
It has a bolt down the bottom of the leg. Technically speaking it should be done with a special tool, but, the right size allen key/socket, coupled with a rattle gun works most times. It's just that the damper rod spins unless you have the special tool to retain it. But a rattle gun as said, will usually work it out eventually. HTH :)
Re: fornt forks
Postby mike-s » Tue Mar 10, 2009 8:28 am
long wood broomstick or assemble the fork up, mount it in a vice on a STURDY bench and have a hefty assistant jam their weight into compressing the fork inner.
Return to GPX & GPZ Discussion
Users browsing this forum: No registered users and 2 guests
