Exhaust Patch
All GPx and GPz Models
Exhaust Patch
Postby corvus2606 » Thu Nov 20, 2008 10:27 am
Hey guys,
I have just noticed a tiny (about 5mm x 2mm) hole in my exhaust, and was wondering if there is anything i can use to patch it, or am i better off going to get it welded. Its on the bottom, so im not fussed about looks
2002 GPX250 - Gone
2003 ER-5 - Gone
corvus2606
Bike: ER5
Re: Exhaust Patch
Postby robracer » Thu Nov 20, 2008 10:32 am
Its more than likely a drain hole if it is a slot, or is it crash damage? or Rust?
Re: Exhaust Patch
Postby corvus2606 » Thu Nov 20, 2008 10:37 am
its definately new, didnt have a real close look as the bike was running when i found it, but I did have a quick feel, and it feels pretty manufactured come to think of it. Might have to take a closer look.
but if it is damage, what would be the best course of action?
2002 GPX250 - Gone
2003 ER-5 - Gone
corvus2606
Bike: ER5
Re: Exhaust Patch
Postby robracer » Thu Nov 20, 2008 11:50 am
corvus2606 wrote:but if it is damage, what would be the best course of action?
I would suss it first, then if it is damage you can get an exhaust repair kit from repco etc
Re: Exhaust Patch
Postby corvus2606 » Fri Nov 21, 2008 7:06 am
on closer inspection, It was a drain hole, with some dried mud around it, made it feel like rust.
Exhaust is in surprisingly good nick now that i look at it
2002 GPX250 - Gone
2003 ER-5 - Gone
corvus2606
Bike: ER5
Re: Exhaust Patch
Postby gpxpunk » Fri Nov 21, 2008 7:11 am
mines in crap condition being that it was a rental bike, had been dropped on both sides and they were hitting the rear bar, the left has a dent on the inside and the other made one of the clips that holds the brake line wear away. all fixed now it has free movement {ie. move the muffles to the outside of the rear pegs}. 8)
1987 GPX250R. memories
2002 ZX7R . sold!!!!
gpxpunk
Re: Exhaust Patch
Postby robracer » Fri Nov 21, 2008 7:15 am
corvus2606 wrote:on closer inspection, It was a drain hole,
Good to hear there is no work required :)
Re: Exhaust Patch
Postby corvus2606 » Fri Nov 21, 2008 8:35 am
the right side is in good nick, except for a minor scuff on the side reom a previous owner, the left however, has a big dent where the sentre stand got bent in to it when the guy at some stage managed to drop it, bent the stand in far enough it was touching the chain :shock:
thats been fixed, and a new chain fitted. not sure if i should bother with fixing up the dent on the exhaust though, its not broken, just cosmetic really.
but other than that, and currently being caked with mud and needing a wash, its a good bike
2002 GPX250 - Gone
2003 ER-5 - Gone
corvus2606
Bike: ER5
Re: Exhaust Patch
Postby gpxpunk » Fri Nov 21, 2008 9:01 am
I wouldnt worry about it, if its a bike you going to get rid of later on who cares, apart from resale. If its cosmetic dont worry about it
gpxpunk
Return to GPX & GPZ Discussion
