Lowering a 87 GPX RII
All GPx and GPz Models
Postby Draven » Mon May 08, 2006 8:23 pm
Hey guys, well heres the deal my missus has the bike bug now and wants her own bike, so im going to give her my GPX and save and get something bigger for myself, but there is one problem she cant touch the ground properly on the GPX and i heard there is alot of people on here who know alot about the GPX's, How do i go about lowering the suspension on the bike is it hard job or can i do it myself in my garage?
Any help will be greatly apreciated :)
Cheers Greg
Image Image
RESIDENT BARTENDER
Draven
Postby wazza1234 » Mon May 08, 2006 10:24 pm
how short is this woman?!?!??? :shock:
wazza1234
Bike: ZZR250
Postby ZZRCHIKKY » Mon May 08, 2006 10:26 pm
cut out the seat
lower profile tyers
tie down suspention
ummm.. .. . . :roll: thinking
have to see what else mums has done :P
ZZRCHIKKY
Postby Draven » Tue May 09, 2006 12:45 am
wazza1234 wrote:how short is this woman?!?!??? :shock:
She is a short 5ft :?
Image Image
RESIDENT BARTENDER
Draven
Postby ZZRCHIKKY » Tue May 09, 2006 3:56 pm
is that compared to a tall 5 ft :P
ZZRCHIKKY
Postby MadKaw » Tue May 09, 2006 4:01 pm
Not much you can do with the GPX as the suspension isn't adjustable..
Usually you can raise the forks in the triple clamps but I believe the top mount on the GPX is solid and doesn't allow the forks to slide thru.
You may be able make some longer dogbones for the rear suspension linkage to drop the back... dunno..?
As suggested, cutting some foam out of the seat may be about it...
Postby Johnnie5 » Tue May 09, 2006 4:21 pm
5ft isnt short ;)
a friend of mine is 4'9 and found the best bike in stock form for her was a Ya#$%a Zeal
seat chop is one option, another is to fit a ZZR shock as this is slightly shorter than a GPX shock 20mm or so, so will give prob an inch or so off the rear, with an added benefit of preload adjustment
If the triple clamps are blanked off at the top there is no reason that you couldnt drill them out so you can drop the forks through, which would be advised if you want to drop the rear
In the end it might be a better option to buy a different bike for her , maybe a postie till she is comfortable riding and can go back to the GPX or something else
Johnnie5
Postby FrogZ » Tue May 09, 2006 4:53 pm
Watch the front forks of Zeal's
They are SO cheap as to be VERY unfunny....
FrogZ
Postby Mizz ZZR » Fri May 12, 2006 8:18 am
Short people rock!
I'm 5 foot exactly and I have a ZZR 600 with a shaved seat and the suspension wound down. In total, its down about 2 inches from standard I think.
If I had a choice I'd choose a lighter bike, but the options are very minimal.
K
2003 ZZR 600
2005 Very Tough Rocket 250
2010 BMW F 800 R
Mizz ZZR
Team ZZR
Bike: Honda
Postby ZZRCHIKKY » Fri May 12, 2006 12:24 pm
misszzr- , i sat on a 600 the other day and it was huge im 165 cm tall ( or so it says on my license hmmm theres home yet :D
ZZRCHIKKY
Return to GPX & GPZ Discussion
