Thanks HB, at this stage yeah the injection is gonna be scrapped. The bike is going to be used as a charity ride bike (Scrapheap Adventure Ride) where minimal expenditure and maximum creativity are the goal, we find ourselves in some out of the way places and I think I'd rather be stuck in the bush with carb troubles than injection troubles. Granted both are hard to fix without support. After that i'll probably "café" it out with some CR and stacks and a 4 into 1 etc. I have a lot of spare modern bike suspension components laying around so will probably do something with those too. If you're after that injection I'm more into trading rather than cash sales, read on and you'll see I need some parts
It seems all I do is throw my cash at the CBX I'm building
On an update, finally got the engine unseized, but couldn't get it to turn a full revolution, turns out the cylinders were really full of junk. Determined to get the head off but no matter what I tried a lot of the cover bolts snapped off in the head and too much heat and a little leverage ended up cracking the cover and a few head fins. Not how I like to roll but this thing really was seized up. The cam cover bolts had all corroded and "grown" in the cover etc. Anyway, once I got the head off I found this
I took the head and cover down to Hugh at Robinsons engineering in Bathurst and hopefully he can do some repairs.
I did a quick hone on the cylinders and three came up well enough, the middle one though is pretty bad. Not bad enough to break rings though so will probably just re-ring this time and let it blow a bit of smoke. I see Cruisinimage has 1170 kits for $200 which is very tempting but I don't know how good the bottom end is, may just make matters worse.
