Switch to full style
ZZR 250, 600, 1100 & 1200
Post a reply
zzr250 problems
Sat Oct 23, 2010 4:43 pm
sup peeps,
im new to the bike world and recently bought a zzr250. when i ride on high revs, a weird smell comes out and smokes up. today i was riding and the thing started misfiring and turning off.. i then saw leaking coolant and oil. any help would be good!
cheers,
elz
Re: zzr250 problems
Sat Oct 23, 2010 9:16 pm
Are they leaking from the same spot or seperately? and whereabouts are they leaking from? Have you checked the oil/rad fluid to make sure they aren't milky? Milky = oil and radiator fluid are mixing and it could be a bit of a problem with a seal or gasket..
Re: zzr250 problems
Mon Oct 25, 2010 6:27 pm
they are leaking seperately.. oil is coming from the sump (which was put on by a blue sealant). i went and bought the kawasaki oil filter + O ring today. im hoping this might fix the leak but the idle is still abit funny and cuts out still.
Post a reply
