Switch to full style
ZZR 250, 600, 1100 & 1200
Post a reply
zzr250 intermittent engine problem need help
Tue Sep 21, 2010 10:12 pm
Hi I'm new to site. Just got a ZZR250 on the weekend.
If anyone can give me some ideas on where to start trouble shooting it would be great.
My first ride and the bikes engine cut out twice!! Was riding for about 20min before it cut out the first time. I thought it was running out of fuel as it seemed to splutter for about 30 secs to a min before it died. Found the fuel tap and turned it to reserve (ended up being about 7 litres in tank when I filled up). It still would not start. Battery died.... great! I was on a good sized hill (Maquarie pass, Wollongong) so I decided to try and clutch start it. Yeah that worked great, bike worked fine for 5 min, until I caught up to some cars, I backed right off to give myself some space (very low speed and RPM). When I went to take off again, the bike spluttered and died, I couldn't clutch start it. So I rolled down hill for a few minutes. Tried clutch starting it again and it fired. It went fine for the 15min ride home????
I know the previous owner and this is the first time it has played up.
It has been parked outside on and off for a few months (water issues??)
It was very foggy 5 minutes before it died the first time. Could the mist have caused an electrical problem??
Where do I start, or do wait and see if it happens again??
Update (2 days later): I just went for a 1hr ride and no probs. Do I pretend it didn't happen?
Re: zzr250 intermittent engine problem need help
Mon Oct 11, 2010 1:32 pm
Seems to have fixed itself???
Maybe it was water getting into electrics somewhere?? :)
Mon Oct 11, 2010 1:39 pm
drain tank water in fuel?
Mon Oct 11, 2010 1:47 pm
have you checked the fuel line from that tank to the carby? or the switch itself? my old zzr had a problem like that and it was the diaphragm in the switch i think....it was a few years back now...
Mon Oct 11, 2010 7:17 pm
Vacuum hose to tap?
Floats sticking?
Tim's thought?
Thu Oct 14, 2010 4:45 pm
If it plays up again check the tank breather. From memory they are part of the filler cap assembly. If that is blocked it causes a vacuum (vapour lock) inside the take, not allowing fuel to run out. Similarto sticking a straw in a glass of water, sticking your finger over the top of the straw and lifting it out. The water stays in the straw the same as your fuel will stay in your tank.
Fri Oct 15, 2010 8:54 am
Stace wrote:If it plays up again check the tank breather. From memory they are part of the filler cap assembly. If that is blocked it causes a vacuum (vapour lock) inside the take, not allowing fuel to run out. Similarto sticking a straw in a glass of water, sticking your finger over the top of the straw and lifting it out. The water stays in the straw the same as your fuel will stay in your tank.
.. so that's why it's soo hard to syphon petrol with a straw! :lol:
Fri Oct 15, 2010 8:56 am
Exactly........ Although i do know a chick that can do it. But she's also been known to suck start Kenworths :shock:
Fri Oct 15, 2010 8:58 am
... one word..... "talented" :kuda:
Post a reply
