Switch to full style
ZZR 250, 600, 1100 & 1200
Post a reply
ZZR250 not starting in the morning only
Wed Jul 30, 2008 6:00 pm
Hey guys,
my ZZr250 is not starting up in the morning, i need either to push start it or jump start it from my car (while car is NOT turned on of course)
I tested the battery twice and its always charged, the bike cranks the first and second time and then on the third i hear a click click click click... sound.
After it's on, if i put it off and then turn it back on again, all is good.
Any advice is much appreciated.
Re: ZZR250 not starting in the morning only
Wed Jul 30, 2008 6:17 pm
Paul, do you know how old the battery is ? How are you checking the charge on the battery ?
Wed Jul 30, 2008 6:47 pm
Hey mate,
the battery is almost a year old and i took it to a bike shop to get it tested.
Thx for your reply :)
Wed Jul 30, 2008 6:55 pm
Check the positive and negative connections are clean and tight ( although if you've had it to a bike shop, I would think they should have checked this ).
If you can also check the connections to the starter motor as well.
Is the bike garaged overnight ? What area do you live ?
Wed Jul 30, 2008 7:30 pm
I checked and cleaned the connections yesterday and no, the bike is not garaged , i only cover it when it's raining and i live around parramatta.
PS: i ride ion the rain all the time, not sure if this would cause any issues.
Wed Jul 30, 2008 7:39 pm
As I'm only your garden variety electrician ( not auto ) I'll defer to the experts on this one ! However, parked in the open in winter is not a good thing for batteries and riding in all weather means moisture gets to all the wrong places. There is also the outside chance the battery has a dead cell, which will prevent it holding a full charge, and in cold weather this puts more stress on the battery.
Over to the experts ! :?
Wed Jul 30, 2008 7:47 pm
6maniac wrote:As I'm only your garden variety electrician ( not auto ) I'll defer to the experts on this one ! However, parked in the open in winter is not a good thing for batteries and riding in all weather means moisture gets to all the wrong places. There is also the outside chance the battery has a dead cell, which will prevent it holding a full charge, and in cold weather this puts more stress on the battery.
Thats sound about right to me Ron.
Wed Jul 30, 2008 7:54 pm
The clicking from the starter solenoid shows that the charge is not high enough to crank the bike over... Battery is more than likely stuffed :?
Appolo batteries in Bearing Rd Seven Hills (Cnr Bearing & Powers Rd) can test the battery & if need be sell you a new one cheaper than the shops 8)
Wed Jul 30, 2008 7:59 pm
Another thought, Paul - if the battery is not yet 12 months old, it should still be under warranty. May be an idea to have an auto-electrician load test the battery - this could possibly tell if it is faulty. Then you could probably get a replacement under warranty ? Good luck, Ron.
Wed Jul 30, 2008 8:26 pm
If the battery has a dead cell, it would have shown up when it was tested...
Now if they tested it with just a multimeter, then it very well could have shown 13.8 - 14.4 volts across the terminals. From the sounds of it however, under load it would have failed.
These batteries are designed for starting and have a Cold Cranking Amp rating. They can only be accurately tested under a load.
The colder the temperature the harder the battery has to work to produce enough amps to kick it over - hence the fact that it's not starting in the morning...
HTH
Wed Jul 30, 2008 8:31 pm
hello2.gif :prayer: iamwithstupid.gif
Thank you, Expert :D ;)
Wed Jul 30, 2008 9:03 pm
Awesome stuff, thanks for your replies guys :)
Robracer, i'll give the guys at Appolo batteries a visit and see how we again.
Thanks again everyone!
Wed Jul 30, 2008 10:21 pm
6maniac wrote:hello2.gif :prayer: iamwithstupid.gif
I'm more than just EC ;)
But far from an expert...
Sat Aug 02, 2008 11:27 am
Hey guys,
just came back from Lion batteries in Seven Hills and the guys their just tested the battery with a multimeter and he said it wasn't showing enough voltage but he suggested that i fully charge the battery and come back for him to fully test it again. He is suspecting it might be the alternator not charging the battery enough.
Any ideas how to test and alternator?
PS: i took the bike for like 2 hour rides 2 weeks ago but still had the same problem. I might buy one a small charger, fully charge the battery and see how i go.
Sat Aug 02, 2008 11:50 am
G'day Paul - if you have access to a multimeter and the battery is fully charged
1. Start engine - warm up to operating temp.
2. Connect multimeter at battery terminals and note reading with headlight on and off ( you may have to remove the plug at the headlight bulb )
3. At idle or low revs the reading should be close to nominal battery voltage i.e. 12volts
4. Increase engine revs - the reading should rise but should stay between 14 - 15 volts.
5. If the volts are much higher, then the regulator/rectifier is suspect ( or the connections and leads to same )
6. If the volts do not rise as revs increase the regulator/rectifier is suspect or the alternator output is not sufficient for the load.
Cheers, Ron. :D
Post a reply
