04 636 air intake help help pls!!
Postby hidepenny » Mon May 29, 2006 12:49 pm
hi does anyone know what will happen if water has gone from the front air inlet ???
anything to stop it to gointo the engine???
hidepenny
Postby mike-s » Mon May 29, 2006 1:24 pm
how much water are we talking about?
a little = not a worry, over 80ml = a worry, over 200ml, you go crazy with the hose?
i think the air fiter goes gorizontally across the airbox, i dont know if/where there is space for water to "catch" in the airbox to stop it being ingested by the injun
Postby hidepenny » Mon May 29, 2006 4:01 pm
there's no machianism to stop water going in to the engine from the intake? :shock:
hidepenny
Postby MickLC » Mon May 29, 2006 4:14 pm
There's usually some little drain holes somewhere in the system that let a little bit of water out if the hose splashes it or you have a ride in the rain. They won't cope with the hose being bunged in the intake though, but the air filter might slow things down a bit if you haven't turned it over.
Users browsing this forum: No registered users and 13 guests
