zx636r oil filter size
Postby hidepenny » Fri May 19, 2006 11:49 am
anyone knows???? as i'm buying or thinking to buy , will it fit???
http://cgi.ebay.com.au/OIL-FILTER-RATCH ... dZViewItem
hidepenny
Postby hidepenny » Fri May 19, 2006 11:50 am
well priced too????
hidepenny
Postby Stretchy » Fri May 19, 2006 5:15 pm
That is the one i was trying to say in your other thread, it works great.
Yes it should fit, the claw opens up as you turn it so it works both directions.
Stretchy
Postby Barrabob » Fri May 19, 2006 9:24 pm
The 636 has a retasining clip on the oil filter hidepenny make sure you take that off first and i fitted most of my oilfilters so i can get them off easy too but if i get a tough one I just punch a hole through it with a phillips head screwdriver and use that as a handlle, works a treat. :D
Barrabob
Postby Minorci » Fri May 19, 2006 9:29 pm
Just need to make sure you have plenty of rag underneath cause it pisses out everywhere ;) I used that trick when i got the factory filter off
Minorci
Postby mitch179 » Tue May 23, 2006 11:51 pm
bob is right about the philips head trick! cheaper than buying the tool :)
i found mine came off easy ... just used my hand! just remember u dont have to do them up super duper tight, just screw it on .. then give it a nip sorta thing to secure it ..
mitch179
Postby sluglie » Wed May 24, 2006 7:46 am
just use k&n oil filters, they have a 19mm nut on top so all you ever need is a spanner (which i am sure you have somewhere)
the master of percussive maintenance
sluglie
