ZX9R where to take a 12V supply??
Postby Robsalvv » Wed Nov 09, 2005 3:14 pm
Just got me a dub bub and want to wire in a type of GPS unit and mount it on top of the instrument cluster.
Any suggestions for the best place to piggy back off a couple of wires for a 12V power source for the unit??
Rob
Battered and bruised '029R - Gold spark - with Kerker tones
Road focused '029R Blue - with Yoshi tones
Robsalvv
Postby mrmina » Wed Nov 09, 2005 3:17 pm
mate u'd want to wire it to a place where there wouldnt be much spikes in the electrical supply.
Best would be off the battery via a fuse. See the mA rating of the unit and use a fuse to suit.
Postby javaman » Wed Nov 09, 2005 3:26 pm
I have GPS on the 6R and could not see much difference with 9R, fairing etc. I connected the power to the city light (that small light in the middle). Easy and it is fused as well. The connection point is cigarette lighter (female) from supercheap auto.
Been connecting portable tyre pump with no problems as well.
-ariel circa 2007
http://GPZninja.blogspot.com/
javaman
Bike: GPz900
Postby Robsalvv » Wed Nov 09, 2005 3:33 pm
MrMina, thanks for the suggestion. I considered the battery, but was hoping for a closer point - near the instrument cluster. Plus the unit has a built in fuse - so I was banking on that to allow me a quick fit up.
JavaMan - I think that might be the answer :) That light is always on. A quick check with the multimeter for polarity and all will be well in a jiff.
Thanks guys.
Rob
Robsalvv
Postby mike-s » Wed Nov 09, 2005 3:48 pm
You could always get a dicksmiths/jaycer inlne power filter kit that makes the power peak out at 12 maybe 13v or so so it doesnt smoke the gps?
Postby icebreaker » Wed Nov 09, 2005 3:55 pm
The amount of current being drawn.. sweet fa.. I'd say the parking light would be fine, considering the loom to that wouldn't be under much load, compared to the head lights if you're running better than stock globs.
Ducati Monster S2R1000
icebreaker
State: Tasmania
Postby krusty » Wed Nov 09, 2005 9:03 pm
You may even find that there is an unused accessory fuse in the junction box you could run a wire from.
krusty
Postby SocialSecurity » Wed Nov 09, 2005 11:12 pm
does it need both constant power and ignition power feeds to it, to keep settings (like a car head unit) ?
SocialSecurity
Postby Robsalvv » Thu Nov 10, 2005 8:18 am
No the GPS unit doesn't need a constant source of power.
I have thought about the fuse box and battery - but they're plan B and C if there wasn't a suitable spot I could grab power near the instrument cluster.
Rob
Robsalvv
Re: ZX9R where to take a 12V supply??
Postby Robsalvv » Mon Sep 03, 2007 6:07 pm
Saw this old thread of mine.
FWIW, for the record, the F1/F2 ZX9R's have a spare slot in the fuse box which is labelled as "accessories". It's an available possy in the fuse box and is active when the ignition is on. I'm currently running heated grips and a basic GPS from that spot.
Very convenient Mr Kwakasan!
Rob
Robsalvv
Users browsing this forum: No registered users and 16 guests
