04 ZX636 speedo falt
Postby varden » Fri Sep 09, 2005 11:07 pm
any thoughts on why my digital speedo/odometer has stopped working?
Rest of the instrument cluster is fine, could the sender be fouled up??
Thoughts....cos it not go now and cluster only has 200km on it!
is the sender that device on the front sproket cover with the wires running to it?
varden
Postby Barrabob » Sat Sep 10, 2005 6:04 am
Yep the sender is the thing that screws into the left hand side cover, could try giving the conection into the back of the speedo a wiggle too but be carefull the pins are tiny and delicate.
Barrabob
Postby ttc » Sat Sep 10, 2005 6:30 am
i'd get it looked at under warranty.. it's a known prob with these babies...
ttc
Team Black
Postby varden » Sat Sep 10, 2005 12:57 pm
hmmmm....the plug into the back of the cluster is a bit suspect after being ripped out of the instrument cluster when the previous owner wrote the bike off.
Which is part of the reason why getting it repaired under warranty is not my first choice. Good excuse for local kawasaki dealer to pass the buck.
varden
