How to remove the rear wheel from a ZX9r
Postby rexxxy » Sun Sep 04, 2005 8:02 pm
As topic states, how do I remove the rear wheel from my '02 ZX9r?
Im sure its incredibly easy but I dont want to start it and bugger it up (if thats possible). A search on Google came up with nothing, a search on these forums came up with nothing (I have been searching on 'wheel removal').
Anyone know of a guide or can you list the steps required?
I have a flat and dont want to use one of those emegency flat repairer things.
thanks in advance!
rexxxy
Postby Maty10 » Sun Sep 04, 2005 8:37 pm
1. Raise the rear securely (jack under shock, stand, etc)
2. Back off locking nut on chain tensioners. It's the nut touching the bolt running through the swingarm. Bring it right back to the bolt head for ease.
3. Spin chain tensioner bolt all the way into the swinarm, ie so the chain is going slack.
3. Use big arse socket to undo nut on left hand side. It's around 32mm or something like that. Alternative there is a spanner and handle type arrangement in the tool kit for it.
4. Knock axle through from left to right with rubber mallet.
5. Should be able to pull axle completely through from there by hand. Get a mate to support the wheel or use your foot or something. Be ready for the two shims to fall out and take not of which side they came from. Also be ready for caliper to move or fall even once the wheel comes loose. Move it out the way and don't leave it hanging by its fluid line.
6. Installation is opposite, just make sure the shims are on the right sides. Adjust chain tension evenly (ie a turn or two each side at a time, there's marks there to help initially). And finally tighten axle nut up damn tight, around 100nm. And of course a new cotter pin to hold it there.
Maty10
Postby Maty10 » Sun Sep 04, 2005 8:40 pm
And of course make sure the brake is not pumped while the wheel is out, there's the danger the pistons might leave the caliper. Pump the brake lever a few times after everything is back together to ensure the pads are sitting on the disc properly.
Maty10
Postby rexxxy » Sun Sep 04, 2005 9:38 pm
Hey Maty10,
Thankyou so much for that info, I just walked back in from the garage after staring at the bike for 30 minutes. I removed the cotter pin and decided it would be best to find out the correct way to do it.
I will have a crack tommorow morning before work.
rexxxy
