Reversing indicator phasing on ZX9R - any ideas?
Postby Loz » Tue Apr 10, 2007 11:42 am
A strange issue: when I flick the Minja's indicators on, they start on the "off" part of their cycle, meaning that there's almost a second before the light comes on.
I dunno about you guys but I'm a bit of a commando in traffic, and I do a lot of splitting and quick lane changes. I do like to be nice to the poor cagers though, and at least give them the right signals. Right now, the things are taking so long to flash on that sometimes on quick moves I've already cancelled the signal by the time it comes on.
Is there an easy electrical fix for this? Anyone got any ideas?
Loz
Postby mfzx6r » Tue Apr 10, 2007 1:14 pm
try an electronic flasher can see how that goes
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
mfzx6r
Postby Poyda » Tue Apr 10, 2007 1:59 pm
Check globe wattage also, i had globes that were too high in watts and were slow to work....or maybe they were just cheap ass globes
Pete
The (no longer) ugly 96 ZX6R
Poyda
Re: Reversing indicator phasing on ZX9R - any ideas?
Postby Gosling1 » Tue Apr 10, 2007 5:21 pm
Loz wrote:A strange issue: when I flick the Minja's indicators on, they start on the "off" part of their cycle, meaning that there's almost a second before the light comes on.
Flashers have a bi-metal strip that has to heat up in order for the flasher unit to work.....this doesn't happen 'instantly', it takes , maybe 1/2 a second or more depending on the flasher.......flashers always start on the 'off' part of their cycle.
Only fix ? Try and electronic flasher unit (as per Marz advice), or, indicate earlier :D (I am being serious.... :D )
Postby Loz » Tue Apr 10, 2007 5:38 pm
Gosling1 wrote:Flashers have a bi-metal strip that has to heat up in order for the flasher unit to work.....this doesn't happen 'instantly', it takes , maybe 1/2 a second or more depending on the flasher.......flashers always start on the 'off' part of their cycle.
Weird, I don't remember this problem on other bikes... And a mate swears his ZX9 doesn't do the same thing. It's not the world's most critical problem, but indicating early does take up some mental bandwidth in thick traffic, and I don't wanna run into copper troubles because of it.
Loz
Postby Gosling1 » Tue Apr 10, 2007 6:16 pm
he might have a different model of flasher and /or bulb wattage. It all makes a difference, some flashers do work quicker than others.....
That owl picture reminds me of an long-banished member. :?
Postby Neka79 » Tue Apr 10, 2007 7:54 pm
Gosling1 wrote:Only fix ? Try and electronic flasher unit (as per Marz advice), or, indicate earlier :D (I am being serious.... :D )
yea..indicate before ur brain tells ya to change lanes..??
Postby Slow and wobbly » Tue Apr 10, 2007 8:18 pm
Your flux capacitor requires replacement - See here on how to build your own
for much cheaper than retail:
http://www.amasci.com/freenrg/bajak1.txt
Slow and wobbly
Postby Gosling1 » Tue Apr 10, 2007 9:02 pm
Neka79 wrote:....yea..indicate before ur brain tells ya to change lanes..??
exactly. Don't you change lanes without thinking about it afterwards ??
:wink:
Postby Neka79 » Tue Apr 10, 2007 10:48 pm
:wink:
umm im pretty sure my brains sends a signal to look at the hot chick in the red barina before anything else computes....
Postby Rossi » Wed Apr 11, 2007 12:12 am
Doh !
Am I the only nutter here that thought.......Kawasaki's don't have a reverse gear :oops:
Electronic flasher relays are about 13 bucks from Repco from memory
Rossi
Postby Gosling1 » Wed Apr 11, 2007 6:14 pm
Yes you are !!
Postby Grasshopper » Mon Apr 16, 2007 10:23 pm
is it any of their business where you are going?
i've done this a thousand times and no-ones ever been hurt. much.
Grasshopper
Bike: ZZR1200
Postby Gosling1 » Tue Apr 17, 2007 6:37 pm
Grasshopper wrote:is it any of their business where you are going?
Have you seen my blinkers ?? Of *course* its none of their business.....
:lol: :lol: :lol:
