Re. backfire on a ZX12R
Postby kawa zx12R » Thu Dec 28, 2006 2:01 pm
:( I have an issue people.... i have a ZX12R that i had for about 3nths.
the bike is great in all aspect, but i have a slight problem... when the bike is reved at over 7000rpm, i have a backfire sound....
Could this be from a leak somewhere lettiing pressure from the exhaust or could it be somthing else.
Please help...
kawa zx12R
Re: Re. backfire on a ZX12R
Postby Jonno » Thu Dec 28, 2006 2:59 pm
kawa zx12R wrote::( I have an issue people.... i have a ZX12R that i had for about 3nths.
Please help...
What model/year, any mods like pc3, zorst etc?
Postby kawa zx12R » Thu Dec 28, 2006 3:12 pm
none whats so ever, still stock as.
kawa zx12R
Postby deafwish » Thu Dec 28, 2006 3:15 pm
Disable the KLEEN system.
That should sort out the crackling sound.
deafwish
Postby kawa zx12R » Thu Dec 28, 2006 3:19 pm
[quote]
That should sort out the crackling sound"
i don't have crackling... its more like a bang after 7000rpm on release of throttle....
kawa zx12R
Postby deafwish » Thu Dec 28, 2006 3:36 pm
It still could very well be the KLEEN system!
Tried plugging up the main tube from your airbox?
Do a search on here on the KLEEN removal. It may give you some more info to consider.
deafwish
Postby Wattie » Thu Dec 28, 2006 3:37 pm
do the kleen mod ;)
Postby Jonno » Thu Dec 28, 2006 3:37 pm
deafwish wrote:Disable the KLEEN system.
Sorry that can cause it on the 12R (Believe me, I have spent many many hours researching this), the early models can get away with it sometimes with a pc3 but not all have been happy with tuning, many problems. :wink:
Remember kwakka make and design aircraft and were first to introduced ram air to factory sportsbikes and took the competition ages to catch up and still don't get it right, I think when they add resonators and all the other hardware etc to the air ducts they are there for a reason. The later 12R's do not respond well at all to kleen air mod.
I will attatch what I pm'ed to kawa zx12R
Besides just removing it without installing a PC3 is plain silly. :wink:
Ok, can be anything from plugs, computer under the rear seat as some had or developed issues, can also be the full sparkplug stick itself, hell they even had an oil wicking issue on the stator wire and was a recall. Dirty fuel or filter..
I think it is a case of do the obvious first; I am no motorbike mechanical wiz either. But what I can do well is link you to some great WebPages.
http://www.zx-12r.org/Motorcycle_info/Bike_ZX12_Maintenance_index.htm
Look down the lower right side of this page for recalls/ potential problems...
http://www.zx-12r.org/Motorcycle_info/ZX12R_Esthetics_index.htm
http://www.zx-12r.org/Motorcycle_info/Information%20Pages/PopularLA12MODS.htm
In the last link don't do the kleen air mod, some speculation as to if it causes misfire, maybe worth seeing if someone has done it to yours previously, also do not bother with the Fitch fuel thing it is crap and exy.
anyway a few hours of light reading there mate and enjoy. Don't forget asking at the USA ZX12R forums, much knowledge is there. :wink:
Linky>>http://zx-12r.org/phpBB2/viewforum.php?f=37&sid=a1eae77ffef9d0ff9d2c689ba4d97e3c
cheers mate, they have to be the best bike on the planet, still.
Postby hoffy » Thu Dec 28, 2006 6:46 pm
Sounds like KLEEN, but mine doesn't do it.
Postby BladeBoy » Thu Dec 28, 2006 8:49 pm
hoffy wrote:Sounds like KLEEN, but mine doesn't do it.
You don't rev it past 7000RPM Hoffy :wink:
BladeBoy
Postby hoffy » Thu Dec 28, 2006 9:59 pm
Id still kick your ass without hitting 4,000rpm :lol:
nah seriously the KLEEN makes the bike very *poppy* when you get off the throttle at high revs, it has to be it.
Postby BladeBoy » Thu Dec 28, 2006 10:06 pm
In your dreams Hoffy :lol: At least I don't remove crap from mine to make it run properly :shock: :lol: :lol: :lol:
BladeBoy
Postby hoffy » Thu Dec 28, 2006 10:14 pm
by crap I would assume you as the rider, in which case your bike would run better :lol: :lol:
Honda Boy :lol:
Postby Barrabob » Fri Dec 29, 2006 1:10 am
Air filter??? If you have been doing a lot of bugs they block up and make it run rich....I have seen trained technicians do a service without cleaning out the air filter tsk,tsc,tsc welll it worth a look anyway and you could do the clean mod while you are in their.
Basically the kleen system injects air into the exhaust to reburn any unburnt fuel which is the popping so if it has a blocked airfilter it could be very rich and popping could also be a partially blocked fuel injecter although i hear minimal complaints except from people running dodgy fuel but you never know.
Is the can on tight with no exhaust leaks seeing as how its been going bang a bit lately???
All the premium type fuels have injector cleaner of some sort blended into them because they are designed for high performance injected enines.
Barrabob
Postby BladeBoy » Fri Dec 29, 2006 5:06 am
Honda Boy :lol:
Mr Honda Boy to you Hoffy 8) and that's not what I meant :twisted:
BladeBoy
Next
cron
