fitted jet kit to 98 zx9r + dyno graph
Postby Nanna10r » Wed Dec 07, 2005 4:02 am
Been reading with interest mate. good stuff.
Cheers Brett
Nanna10r
Postby MadKaw » Wed Dec 07, 2005 6:51 am
You could try scuffing up the metal plates with some rough sand paper or similar.
My clutch would slip in 4th at about 9000 rpm and it was all within the Kawi specs. I put in a set of Barnett springs and it was fine.
Postby SocialSecurity » Wed Dec 07, 2005 2:11 pm
Pontikat wrote:Been reading with interest mate. good stuff.
Cheers Brett
thanks mate... just remember, later model 9R's jet differently to 98/99 9R's incase your gonna have a play 8)
as for the clutch, how much did the springs set you back madkaw?
if its still slipping i might give all the plates a little scuffing, and i might shim up the springs too
SocialSecurity
Postby MadKaw » Wed Dec 07, 2005 3:15 pm
The Barnett springs were about $45 a set from Serco...
Postby SocialSecurity » Wed Dec 07, 2005 6:17 pm
spent half an hour "machining" some 10mm washers to fit under the existing washers for the clutch springs... chucked em in and no more slip, lever doesnt feel any different... case closed as far as im concerned :lol:
the bike sure boogies now, tho i think it definately needs a half a needle clips adjustment... trouble is im not sure which way :? probably richer.. doesnt affect top end, just a slight flat spot around 5ish
hopefully have it sorted before PI, friday next week 8)
SocialSecurity
Postby NinjaMoses » Tue Dec 13, 2005 4:43 am
Sorry for the thread hijack but just wondering...
I have a 98 ZX9 also and am picking up a full Devil exhaust system for it next weekend. I've been looking at getting a +4 igntion advancer, K&N filter and factory pro jet kit to fit along with it.
Is the factory pro jet kit worth getting? I'm a bit confused by the posts in here, are you saying the jet kit comes with 142 mains but they were no good and you had to swap to much bigger ones? Or does the factory pro jet kit come with many different sized main jets?
I didnt realise the stock headers even had a clean air injection type system (I just have a yoshi slip on at the moment on stock headers). I'm guessing the Devil system wont have this though so will be blocking it off also?
Guess I will start with the settings you are using and will go from there.
thanks guys,
Ninjamoses
NinjaMoses
Postby SocialSecurity » Tue Dec 13, 2005 2:30 pm
your hijacking is welcomed :P
the jet kit didnt come with 142's, but somebody had fitted them to my bike previously (must have performed worse than with stock jetting)
the jet kit comes with a pair of 150's, 152's, 158's, 160's, 165's and 168's ... it expects you to still have the 155's fitted to the bike as stock (i didnt so i had to go buy a set)
ive heard dynojet jetkits aint so great, and that ivans are very good for 9R's especially if your running an akra or stock system... both ivans and factory give very good aftersales service and can give plenty of tuning advice too. can definately recommend the factory jetkit and factory +4 advancer tho. I would go with which ever you can get cheaper and easier. I have not got a K&N tho (just pulled the mesh from the stock filter) so dont copy my settings too closely, you'll need bigger mains, richer needles, richer floats and richer pilot screws... try the settings madkaw used on his race bike
what ever kit you do get, study this page very closely as there is no better tuning guide, follow it down to the letter. you'll develop a pretty good feeling for the bikes power band and how & where all the changes you make affect the bike
the clean air injection isnt actually in the headers, it squirts the air into the exhaust port through the head depending on vaccum... definately best removed (block or join the bungs comming out of the rocker cover, the pipe comming out of the airbox and the vacuum lines comming out of the head)
as for my settings, i have since made the bike a half notch richer with very good results, bike has a stonking midrange again and great top end, but the floats are set way too rich so its cactus below about 4k...
i have a sneaking suspicion that its running slightly better on cold nights compared to hot days.... i know the floats are slightly rich but it feels better across the board at night, not sure if i still need to go down a little on the mains or if adjusting the floats should fix everything (currently on 14mm need more like 16mm) .... will get around to sorting the floats and then if its still better on a cold night i might try staggered 155/152 mains .... currently all 155's and 3.5 notches from the top on the needles
SocialSecurity
Postby SocialSecurity » Thu Dec 29, 2005 10:19 am
just saw this....
http://www.muzzys.com/ZX998/index.html
anybody fitted it? :wink:
SocialSecurity
Postby MadKaw » Thu Dec 29, 2005 10:42 am
TKA ran em in 02 / 03 and from what I heard they were a lot of trouble.
The 01 TKA zx9r ran KLX300 pistons and was a 972cc. It was more reliable than the 02 model..
Postby SocialSecurity » Thu Dec 29, 2005 5:45 pm
hmmmm, wonder what a new set of sleeves to suit the pistons would cost....
SocialSecurity
Postby SocialSecurity » Mon Feb 13, 2006 7:58 pm
well, jetting is almost 100%
dropped down to staggered 155 (inner) and 152 (outer) main jets and hey hey - crazy power. midrange is really violent now too, using 2nd clip from the top on the needles.
the bottom end tho, i just cant get perfect :cry: power doesnt come on hard until 4k, and is very fluffy below then... no matter what i set the floats to. oh well, ill just have to live above 4k :twisted:
SocialSecurity
Postby Phil » Mon Feb 13, 2006 8:01 pm
SocialSecurity wrote:well, jetting is almost 100%
the torque kicks in around 4 :lol: , mine is totally ride able under that tho too :wink:
Postby SocialSecurity » Mon Feb 13, 2006 8:03 pm
this really is fluffy down low tho, not so much in first or second cause the revs come up too quick... but rolling along in a higher gear around3k and cranking the throttle open, nothing really happens till it gets close to 4k...
when the bike had overly small mains (150/152 staggered) and the needles set to leanest with 13mm float height, it would power on at 3k like a rocket
SocialSecurity
Postby stevew_zzr » Mon Feb 13, 2006 10:37 pm
Still could be timing related.
Carburettors don't atomise the charge very well, so *generally* speaking the mixture will burn slower (and possibly less completely) so if your timing isn't advanced (at lower rpm) - given the reasonably lean 'stock' fuel curve that you posted earlier - I'd imagine that you are constantly going to be compromising between top end power, and mid-range punch. Unless you get a more robust/programmable ignition system ?
Generally an air:fuel ratio of around 11.8:1 is considered ideal for making the most power at full load. Although the stoichiometric ratio is approx. 14.6:1 the mixture generally burns far too quickly and the flame front catches up with the piston, basically meaning that more heat is absorbed by the piston rather than by the air. Then you have to adjust the timing to suit get rid of detonation.
stevew_zzr
Postby SocialSecurity » Tue Feb 14, 2006 3:14 pm
ive come to the conclusion that timing could well be half the trouble right now.... im running a +4 degree timing advancer and have been running the bike on normal 91 octane unleaded the whole time... set the floats to 14mm and the bike seems lean, almost like its pinging.... set the floats to 13mm and the bike seems really doughy, like its too rich... set it to 13.5mm and its just flat around 3-4k, no nasty vibrations no shuddering just flat.... perhaps +4 degrees timing is just too much to ask of 91 octane fuel? maybe its pinging at the 'ideal' fuel ratio, richen it up to stop it pinging and then its too rich.... also notice it runs much hotter than it should too... tho my cooling system is in tatters :oops:
gonna fill her up with some premium on pay day (im broke now and the tanks full of unleaded) but for the mean time ive pulled the advancer out and put the stock rotor back in and now it feels much different... not quite as snappy to the throttle, but a lot smoother... and in first the wheel didnt just come up like it normally does around 6k, it lept for the sky :shock: so i think ive found my issue... about to fire an email off to Marc Salvisberg from factory pro for a second oppinion
as for ideal ratios, 11.8:1 sounds more ideal for a turbocharged vehicle that has problems with detonation (mostly due to backpressure and high inlet temps) .... most dyno tuners ive spoken to say high 12's low 13's are ideal for peak power...
but on that note, speak to marc and he'll say that 'tuning to a ratio' is a waste of time... and hes right... you tune to best power (on n/a's any way)
SocialSecurity
PreviousNext
