Would my 05 636 be?
Would my 05 636 be?
Postby L3raven » Sun Sep 30, 2007 10:58 pm
stand chain n sprocket size 530 525 or 520?? im buyin new 1's vortex look also should i replace my chain at the same time??
Pops the clutch n falls off haha!!
L3raven
Re: Would my 05 636 be?
Postby J.B » Mon Oct 01, 2007 10:33 am
520 and the front and rear sprockets are 15T and 43T respectively. If you're doing the sprockets, do the chain as well.
J.B
Postby Neka79 » Mon Oct 01, 2007 5:58 pm
J.B wrote:520 and the front and rear sprockets are 15T and 43T respectively. If you're doing the sprockets, do the chain as well.
really?? i thought they were 525.... my zed is 525...
u better check anyway Raven- in case they arent the stock ones anyway!!
and if ur doing one, u do em all, in which case it dont matter if u go 520/525/530 .....
520 is lighter and weaker...
530 will last longer....but heavier..
525 is a good medium...
Postby J.B » Mon Oct 01, 2007 9:51 pm
Neka79 wrote:really?? i thought they were 525.... my zed is 525...
yep, I thought it was odd too but thats what they put in the manual, the 03-04 run 520's as well.
J.B
Postby L3raven » Wed Oct 03, 2007 5:52 pm
525 ppl...
L3raven
Postby Neka79 » Wed Oct 03, 2007 6:32 pm
either way...they say u should do all 3 together anyway, so it wont matter what u get, as long as they all match...
what is on it now might not even be standard!!
if ur gunna go down a tooth on the front for acceleration, id go with a stronger set (525 or 530)..i destroyed the 520 set i had on my 929 really quickly (the shop recom it..what a dick they were)
Postby J.B » Wed Oct 03, 2007 6:33 pm
L3raven wrote:525 ppl...
Really?? Where'd you find that?
J.B
Postby GForce » Wed Oct 03, 2007 10:43 pm
mine is a 520 and the manual says its a 520 too with a 15f and 43r sprocket.
GForce
Postby L3raven » Wed Oct 03, 2007 10:48 pm
thats how i bought it so might have 2 check with the guy i bought it off 2 wat it is running as in the sprocket sizing.
L3raven
Postby Neka79 » Wed Oct 03, 2007 11:16 pm
if 15/43 is the standard.... well me being me, and loving acceleration and wheelies ...
id go a 525 14/43
but if i was in the NT with no speed limits...and 250+ was often..id go 525 14/43 anyway..cos ud still get close to 250kph but get there a bit quicker and more funly (is that even a word??)
