A true 4 seasons jacket? Teknic Sprint Labyrinth
Re: A true 4 seasons jacket? Teknic Sprint Labyrinth
Postby Strika » Fri Dec 14, 2007 11:35 am
Mick C wrote:Inside, but with the Summit 2 I have to make sure they are a long way up under the sleeve because the liner ends about an inch or two short of the start of the cuff. If I wear it with the thermal liner in it will still soak up the arm and still make your sleeve wet...did I mention how much I hate this jacket?
I am sure I will find some disadvantages somewhere along the line, but that was one ofthe reasons I ended up parting with the cash for this one, as the waterproofing is part of the OUTER jacket. But it is removed unless it's either feckin cold, or pissing down! I can't wait to wear it up the snowies in winter, it's gunna be toasty with all the segments locked and loaded! I just hope it doesn't leak too much. They all leak eventually, but hopefully it will be in the 5th or 6th hour not the 1st or 2nd!!! ;)
Previous
