My new paint is chipping and scratching really easily and I don't know if its the paint or the painter or something else.
Its breaking my heart
photomike666 wrote:I found this, as I think did Dan.
My theory is that paint shops cheapskate on the paint and use fewer layers that the manufacturers. Also, you can add hardener to the top layer to prelong the surface - as a cost saving device some paint shops may not do this. Combine these and you get thin, weak paint.
I'm presently teaching myself to paint for when my race glass turns up. I'm using more layers, hardener in the top two coats and then a clear layer. Hopefully if I drop it at the track it will just bounce
burkys_ninja wrote:photomike666 wrote:I found this, as I think did Dan.
Lots of clear coat Mike. Even with small chips/scratches most will polish out. Also the paint looks awsome, realy deep(just make sure it has cured eg. oven. Corvette at Summernts in glitter had 26 layers of clear(just to get a level surface). Problem was it was 18mths old and still hadn't fully cured.
As for the hardest paint, that winner is 2 pak, problem it 2 pak is a pain in the ass to use. I have done 2 pak at home in the garage but the over spray sticks to anything and everything. The worst part is it does not cure like acrylic, it will go tacky and this includes anything it comes in contact with.
2 pac tends to be a pain to touch up. But also looks great out of the gun without the rub back/cut/polish.
Pontikat wrote:Its softer then OEM has they have to push the jobs through with $$$ being the bigger picture.
Buy some paint protector sheeting from Supercheap & take your Time watching Mal fit it up Karen. I think he'll need a runner for beer though.
Poor Yappa's "Ten goes to get it right paint job" on "the Firecracka" got a 20cent piece size stone chip beside the headlight first ride after he finnally accepted the repair. We all sat in a big circled & howled for 15 minutes.
Return to Bodywork & Bling Mods
