I have managed to get it to this stage;
Will this be strong enough or do I need to reinforce the inside? If so, what with?
Thank you.Johnnie5 wrote:looks like just a nose piece , depending on how good your work is , it should be ok nice welding btw![]()
what is important is when you put the bike back together that all the panels fit properly and all the brackets are in the right spot , if you have to force things to get the bolts to line up this puts pressure on the plastics and this is the reason that fairings crack and will crack along the previous breaks
Return to Bodywork & Bling Mods
