front indicator wiring question
Postby hidepenny » Fri Aug 11, 2006 9:11 am
does any one know which wire goes with what?
i have an indicator which has 2 wires one black and one white, does it matter if i experiement each into different hole in the plug?
hidepenny
Postby BladeBoy » Fri Aug 11, 2006 10:41 am
No, don't matter, it will have floating earth, just make them the same.
BladeBoy
Postby Duane » Fri Aug 11, 2006 10:45 am
Just plug it in and see if it works, if it doesnt, switch it over. but I'd assume that it wouldnt matter which way you plugged it in......
www.bromancer.com.au
Duane
Postby jpbikeboy » Fri Aug 11, 2006 4:45 pm
except if you have LED indicators. Won't hurt it if they,re the wrong way round just won't work.
jpbikeboy
Return to Bodywork & Bling Mods
Users browsing this forum: No registered users and 2 guests
