Switch to full style
Post a reply
R&G knobs
Thu Aug 31, 2006 4:18 pm
Just wondering if anyone has R&G knobs that go through the fairing? I was wondering what's the go with removing an engine mounting bolt whenever you want to take your fairings off? Seeing as they are a torqued bolt it must bugger them eventually.
Thu Aug 31, 2006 5:17 pm
Dunno if it buggers them.
I had this setup on the ZZR600 - was a bitch to have to remove them to remove the fairing, but I put up with it.
Might cause a problem over time - but how many times would you have to torque a bolt before it fails? I'd assume more often than you'd service the bike.
ty
Thu Aug 31, 2006 5:24 pm
mate if ur crash knobs go through the fairing, u dont have to remove the crash knobs everytime u take the fairing off.
Thu Aug 31, 2006 6:54 pm
:oops: I thought the knob had a skinny bit that went through then got wider :oops:
Thu Aug 31, 2006 7:39 pm
Wharbat darbid yarbou sarbay?
Sara said " what ever drugs Tony is on he should back them off a little "
Fri Sep 01, 2006 12:21 am
I have a set of the R&G ones on my 2000 ZX6R(thats for sale)
You get replacement engine bolts that are longer.
The knob then slides onto them and is then bolted on.
To take a panel off you just undo the nut and remove the knob. The bolt stays in there.
Fri Sep 01, 2006 11:20 am
was diff on the ZZR600.
As AussieNinja said there's a skinny bit that actually goes through the fairing, so in order to take the fairing off you had to take the knob off.
To get the knob off you either had to find a skinny double-jointed 10 year old to weave their arm inside the fairing to get a spanner to hold the nut of the bolt still while you then undo the bolt, or you loose some skin and do the same.
See http://members.ozemail.com.au/~tony.you ... index.html
I wish I was on whatever you think I'm on - might be nice
ty
Fri Sep 01, 2006 8:02 pm
ty wrote:was diff on the ZZR600.
ty
i know which one'e ur talking about now.....
well yes u might cross some problems..... buy the big chunky ones where u have to cut the fairing, its easier
Post a reply
