Wheel Bearings
Wheel Bearings
Postby Duane » Fri Apr 28, 2006 1:40 pm
Front wheel bearings about to go (will get replaced asap) however, has anyone ever had one of these go? and also, what did it feel like, and what happened when it did give up the ghost?
www.bromancer.com.au
Duane
Postby Felix » Fri Apr 28, 2006 1:48 pm
It'll probably make a big grinding noise, still spin round and round but there will be a fair amount of drag. Not likely to be catastrauphic, but replace as soon as possible. Shouldn't take long...
- Team Furball -
Felix
State: Overseas
Postby Rossi » Fri Apr 28, 2006 3:59 pm
Mate,
it will be a lot cheaper to use a bearing company and not a motorcycle shop to get your bearings from
Rossi
Postby Johnnie5 » Fri Apr 28, 2006 4:52 pm
bad wheel bearings are BAD
first they start to make a noise, eventually they collapse which is really BAD
it also makes em a real bitch to get out
get the bearings from a bearing place they have a small number on them
prob $5-$10 a bearing
Mate with Aprillia needed 2 rear bearings , the sprcoket bearing and a couple of seals $50 at the bearing mob with the list in hand that we foound on the web ,
$490 from aprilia :shock: a 10 x markup and this is besides the fact that the bearing mob makes plenty out of it as well
Johnnie5
Postby Tones » Fri Apr 28, 2006 10:35 pm
Yeps bearing places usually source from OEM suppliers as well...or sometimes better than OEM. Try Tony at Hallam bearings he should be able to help you out.
Tones
Postby mrmina » Sun Apr 30, 2006 11:13 am
Johnnie5 wrote:bad wheel bearings are BAD
wheel bearing are bad mmmkay
Postby fat460 » Tue May 02, 2006 7:03 pm
Yeah - don't risk it. Once wheel bearings start to go they progress real quick. It still pays to check your prices. Mine were actually cheaper genuine than from a bearing place - I think they were a odd size from memory. Nice easy job to do anyway.
Paul.
GIVE IT THE BEJEEZUS
fat460
Postby ozx6r » Tue May 02, 2006 7:55 pm
http://www.cyclecat.com/Cebera02-01.htm
these look nice
might be a bit over board
97 - zx6r
05 - zx10r
ozx6r
Postby RG » Tue May 02, 2006 11:01 pm
mmmkay~
RG
Postby Johnnie5 » Tue May 02, 2006 11:54 pm
ozx6r wrote:http://www.cyclecat.com/Cebera02-01.htm
these look nice
is it just me or does that chick look crosseyed ?
Johnnie5
Postby Johnnie5 » Tue May 02, 2006 11:55 pm
these look nice
Johnnie5
Postby mrmina » Wed May 03, 2006 12:04 pm
she looks alright.
it might be hard for her to guide my dick in her mouth :D
