Engine smokes
Engine smokes
Postby hidepenny » Fri Feb 03, 2006 3:35 pm
lastnite went on a ride with a friend who had FRZ, coz he was abit more experienced rider, i let him ride in front, at a traffic lights he just went on full acceleration and i was right behind him, and all of sudden i couldn't see anything infront of me :shock: as massive white smoke came out of his exhaust
i was pretty sure it wasn't the warming up normal smoke, so i thought may be all old bikes would be the same? i checked mine, throttled on , and "white smokes"!!!! but not as bad as the FZR
so anyone knows what problem it is and how to rectify? or tell me it's not fixable and encourage me to get a new zx6r? :D
hidepenny
Postby Stereo » Fri Feb 03, 2006 3:43 pm
Smoke is usually caused by Oil.... If enough oil is burned it creates a light grey smoke...
Generally happens when someone over fills their oil reserve....
Postby hidepenny » Fri Feb 03, 2006 4:28 pm
so nothing wrong with any components or the engine?
hidepenny
Postby mike-s » Fri Feb 03, 2006 4:40 pm
theres the potential to blow seals, such as the one on the output shaft of the gearbox, etc..
Postby Gosling1 » Fri Feb 03, 2006 4:44 pm
Stereo wrote:Smoke is usually caused by Oil.... If enough oil is burned it creates a light grey smoke...
if your valve stem seals are rooted, you will blow blue smoke until the engine is warmed up.....
Too rich will be a brown or dark grey smoke.......
the only way to fix oil-burning problems is to pull the motor apart and fix whatever it is that is buggered..........valve stem seals and / or hone and re-ring ( or new pistons if the old ones are fully stuffed.)
Postby hidepenny » Fri Feb 03, 2006 6:02 pm
:shock: ..........sounds like a complicated job, or a costly job for someone to do it...... :( :( :( :( :( , hopefully the bike can last me another year or so...........................
hidepenny
Postby Rossi » Fri Feb 03, 2006 6:11 pm
mike-s wrote:theres the potential to blow seals..
Isn't that against the law ???
Rossi
Re: Engine smokes
Postby mick_dundee » Fri Feb 03, 2006 6:55 pm
hidepenny wrote:Engine smokes
Sounds like a job for the quit line, am sure you can get engine patches :)
Postby chameleon » Fri Feb 03, 2006 7:46 pm
that's why they only do it in Antarctica... where no one is watching
chameleon
Postby Gosling1 » Fri Feb 03, 2006 10:00 pm
hidepenny wrote:... :shock: ..........sounds like a complicated job, or a costly job for someone to do it...... :( :( :( :( :( , hopefully the bike can last me another year or so...........................
lots of bikes will blow a *little* weed when they are thrashed hard, its nothing to worry about *most* times, its when you have a noticeable trail of light blue smoke 'haze' following you everywhere........thats when you start to worry........
Rossi - is that frostbite in your beard ????? :shock: :shock:
:D
Re: Engine smokes
Postby HemiDuty » Fri Feb 03, 2006 10:54 pm
As long as it does not do it within 4 metres of a public building entrance, it's OK.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
HemiDuty
cron
