mike-s wrote:Take the tank off, side plastics too (top plastics im unsure if they are one peice with the sides or seperate), you will have to move/ may have to drain and remove the radiator. undo the balancer cross pipe under the bike, then the header bolts (2 per cylender), From there im sure you'd be able to figure out all the pokery jiggery you have to go through to remove them.
Good luck, im going out now to do the reverse on my bike now. Why are you wanting to remove them anyway?
