all the electrics are easy, they're well and truly long enuff, and the choke cable has just enuff length aswell, but the clutch, brake and throttle cables are not gunna make it
first off, does anyone know if there are any other model throttle cables that fit up to the ZX7R and are a little longer (say 10-15cm)? i know its a long shot, but i was kinda hoping to save myself going into a bunch of wreckers with my cables and comparing them....
next up, does anyone know if there are any other bikes with longer clutch lines than the ZX7R? or alternatively, is it possible to extend a clutch line using a small section with the same ends and a suitable bolt?
and lastly, does anyone know a particular model that has a slightly longer lever to splitter section of line for the brakes? its possible a rear brake line off something might work, but i'd guess it'd be a bit long and might end up being a bit spongey or something
i know, i'm a tightarse, but i just dont like the idea of forking out $120 ea for the throttle cables, $80 for the clutch line and $160 for the brakes if i can get away with it cheaper while i'm a bit low on cash....
cheers all
