Hi,
Can anybody help with an issue I have with my speedo cable, On the way to work the other day, had just opened it up briefly, speedo working fine. then next time I look down, no speedo reading or trip meter. I checked the cable wasn't loose at either end, I then removed the inner cable it looks ok, and if insert it into the gauge end and twist it quickly the speedo registers. Could it be the speedo drive next to the fork and if so what do I need to look for. Are they easy enough to get hold of and fit.
Cheers Dave
