valve adjustment
valve adjustment
Postby MrFaulty » Thu Apr 28, 2011 11:32 am
Hi, I have heard that the valves on a bike should be adjusted periodically, is this true? if it is, how often or how do yo tell when it is required? Also, I any suggestions if it is a big job, do I use a standard set of feeler guages?
I have a ZX6RR 2003
Thanks
Ben
MrFaulty
Re: valve adjustment
Postby Wattie » Thu Apr 28, 2011 12:56 pm
Feeler gauges yes.
Factory recommend 24,000kms.
Sooner if your racing.
Postby MrFaulty » Thu Apr 28, 2011 2:14 pm
might be overdue then at close to 35000kms! - commuting only
I have a manual but haven't looked at it, is it a big job? what sort of time should I allow (ie should I wait for a weekend)
MrFaulty
Postby Wattie » Thu Apr 28, 2011 2:30 pm
its a weekend job mate, just checkin them, allow for 4 hours?
if you need shims, its a day job.
Postby MrFaulty » Thu Apr 28, 2011 3:04 pm
Thanks, might put it off for a week or two - wait for a rainy weekend given that I have had the bike off the road because of the damn stator for weeks!
MrFaulty
Postby MrFaulty » Thu Apr 28, 2011 3:49 pm
Thought I had an elecctronic version of the manual for this bike but can't find it, does anyone have one?
Thanks
Ben
MrFaulty
Postby J.B » Fri Apr 29, 2011 10:34 am
Valve adjustment is definently a day job. I have an electronic copy of the manual, 150MB tho.
J.B
Postby Strika » Fri Apr 29, 2011 10:41 am
Shim changes are something you need to prepare for. You either need a shim kit, or a good relationship with a local bike shop who will swap them out.
Remove rocker cover, measure clearances, record them, if all in spec leave. If some out of spec, remove Cams, measure shims, see if you can swap shims from cylinder to cylinder to get right clearances. If no combinations allow for all in spec, remove a replace those that are still out. Remit Cams, remeasure for peace of mind, put it all back together. Hth.
Postby MrFaulty » Fri Apr 29, 2011 11:17 am
J.B wrote:Valve adjustment is definently a day job. I have an electronic copy of the manual, 150MB tho.
Any chance of you advising the specs or burning the manual to CD and posting (obviously I will pay you for your trouble and the CD)?
Thanks
Ben
MrFaulty
Postby J.B » Fri Apr 29, 2011 12:09 pm
Thanks
Ben
Just PM me your postal addy and I'll send you a DVD with all the manuals I've collected so far (never know when someone I know will need one).
J.B
Postby J.B » Fri Apr 29, 2011 4:10 pm
Will post it tomorrow.
J.B
Postby MrFaulty » Mon May 02, 2011 10:50 am
Thanks, much appreciated!
MrFaulty
cron
