PCV ZX6r auto tune install
Postby Blurr » Thu Mar 03, 2011 6:01 pm
Anyone installed one yet?
What wire did they use for the switched power?
Re: PCV ZX6r auto tune install
Postby tim » Thu Mar 03, 2011 7:21 pm
That's a bit dodge they don't tell you which one to use with a little diagram etc like they do with the Powercommanders?
Postby Blurr » Thu Mar 03, 2011 7:28 pm
They comment that most PCV install guides will tell you which wire. However after a bit of googling and searching the PC site thats a bit of a false statement
Postby Dafuzz31 » Fri Mar 04, 2011 11:04 am
Yeah i got them installed.....didnt do it myself....there is a vid on youtube and i got lost after the 1st few secs.....better off gettin someone else to do it.....
ALso have u bought it yet??
Dafuzz31
Postby Glen » Fri Mar 04, 2011 11:53 am
Just remember Russ, never cut the red one......or is that the blue one?
Ohh and get a ZRX you don't have to worry about any of this fancy electrimacle jiggery pokery.....
Postby Blurr » Fri Mar 04, 2011 1:02 pm
Dafuzz31 wrote:Yeah i got them installed.....didnt do it myself....there is a vid on youtube and i got lost after the 1st few secs.....better off gettin someone else to do it.....
Thanks mate but I think I can stumble through it. ;)
Postby Dafuzz31 » Fri Mar 04, 2011 2:13 pm
All good.....where did u buy them from?
Dafuzz31
Postby Blurr » Wed Mar 09, 2011 7:50 pm
Bought them from Motomummy.
Install was easy once I found my Test lamp, which I never knew I had :oops:
Found the 12V switched on my tail light loom. Retapped the O2 sensor hole to accomadate the larger Auto tune sensor and away I go.
Heaps cheaper than a dyno map and the best thing is it is constantly tuning the bike.
You can set the auto tune up so it only starts tuning once above a certain temp and or after a certain amount of running time e.g. 300secs. This allows the engine to warm up and for you to get out on the track before it starts tuning. You dont want fuel rich warm up times and cold engines to alter you base map everytime you start the bike.
Postby Dafuzz31 » Thu Mar 10, 2011 10:03 am
Yeah thats true.....i got local guys to install it as im a tad mechanically retarded. Ohh yeah cool i got mine from them aswell.....i got the PCV/auto tune combo delivered for about $480 i think.
Dafuzz31
cron
