So what’s the downside of using too high an octane fuel? Higher cost with no benefits is one. Paradoxically, another is that burning higher octane fuel in an engine designed to operate at a lower octane rating can produce carbon deposits secondary to partially unburned (slower burning) fuel. These carbon deposits can build up so as to reduce combustion chamber volume and effectively raise your compression ratio, causing you to actually need a higher octane grade.
http://www.ducati-upnorth.com/tech/octane.php
due to the difference in international methods of rating octane content i'm just going to call it Regular & Super
my stock ZRX1200 engine is designed to use regular gas, but due to storage issues i use both
i use regular in the Spring, Summer & early Fall
but as the only ethanol free gas available to me is Shell V-Power i switch to super in the late Fall for storage considerations
i also pre-mix the super with a fuel stabilizing product (Klotz Octane Booster) that raises the octane by 2 1/2 numbers ....
so its super duper gas...LOL
btw...i intentionally rev out the motor often while using the super & super duper to avoid carbon build up
so to the point....
although the super gives the illusion of more power due to the smoothness of the engine & deeper exhaust note....
my bike is faster & runs more crisply on the regular
