old brake master cylinder/reservoir
Postby matchan » Tue Oct 19, 2010 9:26 pm
Hi folks, I have a couple of old front brake systems sitting around for my track bike and I'm thinking of fitting one of them back on to replace the brembo setup I have now, it appears the bore in the brembo may be wrong giving all the braking preasure in the last little bit of lever preasure and almost no feel before that.
One system is completely dry, the other still has some very black looking fluid in it, is there anything to beware of before transplanting either onto the trackie, given that it can't really be tested prior to first use at the track?
Matt
matchan
Re: old brake master cylinder/reservoir
Postby MrWasabi » Tue Oct 19, 2010 9:32 pm
Yes, your brembo system must first be installed on my tracky to enhance your braking performance...
Bring them over I can help you with fitting them on my bike ;)
Mistakes:
MrWasabi
Postby zxsixr03 » Tue Oct 19, 2010 9:38 pm
What size is he Brembo?
zxsixr03
Postby matchan » Tue Oct 19, 2010 9:40 pm
18x19
matchan
Postby Blurr » Tue Oct 19, 2010 9:57 pm
I wouldnt have thought that the Brembo would produce that side effect. I had one of those on Nemo and I didnt have those issues with it (except for the standard zx10r shit caliper issue).
I know Dave uses the same with nil effect as well.
The shit thing is that you cant get parts for that unit anymore which makes it harder to service, which is exactly what it might need. Glen from Allfixed can do it and use all the old seals however it is not usual practice.
As to the other MC's. make sure you clean them out first then let them dry overnight. After that all should be good.
Postby robracer » Wed Oct 20, 2010 5:00 am
Blurr wrote: Glen from Allfixed can do it and use all the old seals however it is not usual practice.
What....... do it yourself, all you need is good circlip pliers. Russ when you say the parts are not available is that because they cant be sourced here?
Postby Blurr » Wed Oct 20, 2010 7:37 am
Brembo do not make the seal kits anymore. It made it risky for Glen to service mine after the pin dislodged. If he damaged the seal in anyway it was totally farked
Postby Stace » Wed Oct 20, 2010 7:43 am
Blurr wrote:Brembo do not make the seal kits anymore. It made it risky for Glen to service mine after the pin dislodged. If he damaged the seal in anyway it was totally farked
Would it be that hard to modify to suit a different, readily available seal kit? Just a thought
Stace
Team Bolt
Team Bolt
Postby robracer » Wed Oct 20, 2010 8:37 am
Waiting on Info from my supplier, the forged 19x18 MC is pretty common being the least expensive & is what I had on the Crim but the chances of being able to use non OEM parts would be pretty remote, eg the nissan radial MC I just fitted to the SV is a totally different shape.
Postby robracer » Thu Oct 21, 2010 4:57 am
Just got a quote from my usual supplier in USA / Canada:
Hi Rob, We can get a complete kit for the 19 x 18 Forged Brembo Master Cylinder that includes pushrod, seals, and grease for $39 USD plus $35 USD shipping.
we can also supply kits for the more expensive billet master cylinder.
Jason Dempsey
Bayside Performance
jason@baysideperformance.com
www.baysideperformance.com
Phone: 1 604 325 2252
Toll Free: 1 888 925 2252
Postby Gosling1 » Thu Oct 21, 2010 8:56 pm
Heh Rob - how often do you source stuff from Bayside ? I have thought about using them in the past, how are they with shipping times ?
Postby robracer » Thu Oct 21, 2010 9:24 pm
Gos I have bought a few things from them, emails are usually answered whithin a day
Postage is the usual 1-2 odd weeks, even from Canada. Can't fault them
Postby Gosling1 » Thu Oct 28, 2010 8:24 pm
cheers mate - I think I may give them a nudge for a few bits that are needed in the 4th.......
Postby matchan » Thu Nov 04, 2010 12:49 pm
Blurr wrote:I wouldnt have thought that the Brembo would produce that side effect. I had one of those on Nemo and I didnt have those issues with it (except for the standard zx10r shit caliper issue).
I think I've found the answer (but I could also be talking crap)
It appears all the Brembo M/C are designed primarily for Brembo calipers, all of which are 4 piston, the Tokico calipers on the G model ZX6 are 6 piston, meaning more fluid needs to be moved to displace the extra pistons giving longer lever travel. I believe the 04/05 zx10 also uses a 4 piston setup which is why they don't have the same problem.
Matt
matchan
Users browsing this forum: No registered users and 16 guests
cron
