LLOYD PENN + suspension
Postby Six Addict » Thu Sep 16, 2010 11:53 am
Just got the bike back from a day at Lloyd Penn in artarmon. the bike badly needed the steering head bearings done, and i had also blown a seal which needed attention. I also figured that while the forks were apart, i'd get some heavier springs (birthweek anyone?) put in the front as i was using all the preload to get the right amount of preload (set by dave3 mechanical services)
dropped the bike off to them at 830 and it was ready for my dad to pick up by 230... the workshop is very clean and their work is always quick. they might have also run some brake fluid through the front system cos now the lever is hard as a rock 8)
so anyway having just ridden around town and to work, i can say that the front end feels very tight, but a good tight... no doubt i will play with the damping and rebound setting to accomodate for the new springs but thats for the old road this weekend :twisted: it also looks kinda neat to have all the preload rings showing on the top of the fork instead of having the things buried to get the thing stiff.
another note of detail is that they did return the forks to the position they were set from when dave3 mechanical services helped me fit the MX bars. we pulled the forks through a couple of mm and they matched that perfectly. they also replaced a blown headlight bulb and had a general look over the bike... all expected, but none-the-less something that a lot of shops wont do.
so for the steering head bearings, fork seals, new springs and a general check, the cost came to $690. $350 of which was labour (he estimated 3.5 hours work on the phone to me) and $280 for the pair of springs.
now i'll have to get the rear shock looked at... anyone know of any second hand WP shocks going? either that or i'll take a trip to zeno... :kuda:
Re: LLOYD PENN + suspension
Postby robracer » Thu Sep 16, 2010 12:02 pm
Lloyd may not be the cheapest in town but I would trust him with any work that I cant do myself, did you drop my name Owen?
Postby zxsixr03 » Thu Sep 16, 2010 12:20 pm
Do u know what weight oil he replaced with?
zxsixr03
Postby Six Addict » Thu Sep 16, 2010 2:14 pm
robracer wrote:Lloyd may not be the cheapest in town but I would trust him with any work that I cant do myself, did you drop my name Owen?
i was going to rob, but then i didnt :P thought it might work for me :lol:
Postby Six Addict » Thu Sep 16, 2010 2:16 pm
zxsixr03 wrote:Do u know what weight oil he replaced with?
no i dont, will check the receipt but dont think it will have it... i should note the weight and volume of oil and get the spring rate off him too... he picked it off the chart of the spring manufacturer for a rider of my weight...
Users browsing this forum: No registered users and 19 guests
