Petrol "gushing"
Petrol "gushing"
Postby patboy » Wed Sep 01, 2010 7:54 pm
When I start my GPZ 900R the petrol comes gushing out of the engine directly under the front end of the seat. It only happens upon starting the engine but ALL the petrol comes out. Can anyone explain what this may be? I am thinking a leak in the fuel line or hose and not a faulty fuel tap due to the amount of petrol and speed at which it all comes out. However I am not too knowledgable in this area. I have contacted a mechanic who said he does not work on bikes of this age, so if anyone can help me as to a mechanic, preferably on the north side of Syney or Northern BEaches, I would appreciate it.
Thankyou.
Patboy
patboy
Bike: GPz900
Re: Petrol "gushing"
Postby adge82 » Mon Sep 06, 2010 7:37 pm
Hose from the fuel pump not plugged into the carbs and just throwing fuel out?
Does the motor actually start and run?
adge82
Postby Reedy » Mon Sep 06, 2010 7:46 pm
Give this bloke a call, he's in Artarmon. Nice guy and he gets the job done.
Lloyd Penn Motorcycles, (02) 9906 8488
He does pick ups, tell him the air filter man sent you
Reedy
Bike: Honda
Postby patboy » Mon Sep 06, 2010 10:08 pm
Thanks for those replies. Yes motor does start and run until of course, when the fuel empties. I am thinking of getting a mobie bike mechanic to check it out for me. Thanks again.
patboy
Bike: GPz900
Postby 98ninja » Thu Sep 09, 2010 8:45 pm
fixed?
depending on where you live, i could come and trailer it to a bike shop for ya
99 zx9r - back
98ninja
Postby Gosling1 » Thu Sep 09, 2010 8:51 pm
adge82 wrote:Hose from the fuel pump not plugged into the carbs and just throwing fuel out?
no fuel pump on these models.
Sounds to me like the breather hose, which exits at the rear of the tank - has been swapped with something else. There is no real reason that fuel should be coming out under pressure at all, as these tanks only use gravity feed through the fuel tap to the carbies.....
will be interesting to see what the problem is, when it is diagnosed properly...
Postby z900/zx9 » Fri Sep 10, 2010 12:33 am
If its coming out of the carby overflows then needle/seat could be the offender ;)
[b]Z900, z900RS , H2 Ninja 1000 Supercharged. FPV Supercharged Pursuit ute..
z900/zx9
Postby Strika » Fri Sep 10, 2010 11:39 am
z900/zx9 wrote:If its coming out of the carby overflows then needle/seat could be the offender ;)
I agree! 8) Sticking float by the sounds of it!
Users browsing this forum: No registered users and 35 guests
