Fitting side mount Ohlins Steering damper ZX10R 06 -07
Postby dazz245 » Sun Jun 20, 2010 7:09 pm
Hello I am in need of assistance again, would it be possible to side mount a 150mm Ohlins steering damper on an 06-07 ZX10R?
I have done a bit of searching and found side mounting brackets available on the 04-05 ZX10R but not for the 06-07.
The one I have found is pretty cheap and I have heard the stock 06-07 Ohlins are pretty crap compared to the real Ohlins.
Thanks in advance for your help guys :kuda:
dazz245
Re: Fitting side mount Ohlins Steering damper ZX10R 06 -07
Postby Wattie » Sun Jun 20, 2010 7:47 pm
i dont think there is anywhere for it to mount mate?
why do you want a side mount?
just get a kit put through your stock on for about 150 bucks max?
Postby dazz245 » Sun Jun 20, 2010 8:10 pm
Wattie wrote:i dont think there is anywhere for it to mount mate?
The fella who crashed it took it off before it got salvaged.
I was thinking about doing a side mount because I came across the steering damper at a good price and I also heard that side mounting is better but I'm not sure how better.
dazz245
Postby Wattie » Sun Jun 20, 2010 8:14 pm
generally the side mount ones have a longer stroke, so can be fin tuned more.
honestly, if i was buying as damper, i'd be getting a Scotts Rotary damper. lots of adjustment options.
Postby Gosling1 » Sun Jun 20, 2010 8:19 pm
[quote="Wattie"]....honestly, if i was buying as damper, i'd be getting a Scotts Rotary damper. lots of adjustment options....[quote]
+1
Our suspension guru down here swears by the Scotts dampers, he reckons they are by far the best steering damper on the market.
