Just did this with new lines.
I did back bled the system, using syringe and all. For a first timer It wasn't too difficult at all but still requires a bit of patience. First of all I drained all the fluid using the syringe by sucking up all fluid in MC then caliper nipples. Carefully removed all the old lines making sure no fluid dripped onto anything. Installed the new lines. Using the same old fluid, I got my syringe and put fluid through the system from the nipple. I can hear when the fluid reaches the MC and the air bubbles coming though. I did this for both sides till MC was near full.
The lever was sloppy so I went and did conventional bleeding, luckily I have a one-man bleeding thing (Has a one-way valve) so I dont have to keep opening and shutting the nipple. I kept doing this, pouring the old fluid back into the MC (so theres no wastage I only had 1/2 bottle of new fluid) After about 6 MC worth of bleeding I had virtually no bubbles.
This is where my newbness shows up...
To my shock horror the lever went all the way back. no pressure at all. and so I kept on bleeding it for about 1/2 hour. Finally I gave up. Went to the other side and within the first 2 pumps of the lever, it firmed up. So all I had to do was do this side lol. Oh well. This side was done in 2 mins. I then did a normal fluid change bleed with the new fluid, so I didn't end up wasting any new fluid.
Lever is now firmer then ever before, and should have next to no fade watsoever. Looking forward to tracky days
I'll probably bleed it again after another 200kms or so, just to make sure all bubbles they may have been 'dislodged' comes out.
Pretty straight forward, all in all I reckon if I had to do it again, from starting the back bleeding to having no more air bubbles, for a dry system, would take about half an hour?
EDIT:I also just wanted to give Slipstream Performance
https://www.slipstreamperformance.com.au/store/index.php a little plug as well. Apparently they make the braided lines to order and the ones I got fitted perfectly + are of GREAT quality. I ordered and paid on Thursday, they let me know it was dispatched on Friday, and I got them today at Midday. Got tracking number as well, and kept up to date via emails. That is super quick and for once I got the right parts unlike some other internet experiences I have had.
