removing broken bolts
Postby matchan » Sun Feb 21, 2010 8:36 am
Hey all, I've a broken bolt i need from the frame fairing mount where my slider has snapped off, I know there is a tool for this but can't think of what it's called I figure I'll probably need one again some time so what's it called and would it be available from a regular hardware store?
Matt
matchan
Re: removing broken bolts
Postby Wattie » Sun Feb 21, 2010 8:36 am
easy out?
i think Glen has a set.
Postby ducati_paul » Sun Feb 21, 2010 8:53 am
yeah Eziout, easy out, ezi out, summat like that, I have some you could borrow if Avalon or Lane Cove is anywhere near you :)
ducati_paul
Postby craig » Sun Feb 21, 2010 11:02 am
buy P&N or sutton...........if the bolts stainless....lots of bits to suit.....caution while drilling ;)
or can you get multi grips on it or hacksaw a slot and use a flat blade screw driver, if its not sheered of flush with frame
craig
Postby matchan » Sun Feb 21, 2010 11:50 am
thanks all, Paul, I'm in Chatswood, I'd like to get some for myself but if they prove hard to find I'll take you on your offer to borrow yours.
Matt
matchan
Postby ducati_paul » Sun Feb 21, 2010 1:42 pm
No wuckers but I leave for PI Wednesday arvo ;)
ducati_paul
Postby Gosling1 » Sun Feb 21, 2010 7:12 pm
Frame slider bolt ? I'm guessin' 8mm......an ezi-out will do this, if its 6mm, take a lot of care !
Postby Jonno » Sun Feb 21, 2010 7:31 pm
Many ways to do this, I do this shite everyday, so until I see it I cant any give advice, if you think you have no fukin idea dont make it worse by trying 8)
Postby craig » Mon Feb 22, 2010 6:57 pm
as above that's good advice jonno .................it can get nasty....
craig
Postby woteva » Tue Feb 23, 2010 6:35 pm
If you are going to try ezy-outs, please do centre puch the bolt before drilling to keep the drilled hole in the centre.
ZX6R 1998
GPX250 2006 -- SOLD
http://www.bikepics.com/members/woteva/
woteva
Postby matchan » Tue Apr 13, 2010 9:34 pm
Well, finally got off my butt and did this, thanks everyone for the tips.
Jonno wrote:Many ways to do this, I do this shite everyday, so until I see it I cant any give advice, if you think you have no fukin idea dont make it worse by trying 8)
I don't but you've got to start somewhere and as its a trackie...
woteva wrote:If you are going to try ezy-outs, please do centre puch the bolt before drilling to keep the drilled hole in the centre.
sage advice and given by plenty of people, all worked out ok with an easyout
Matt
matchan
Postby oldman » Wed Apr 14, 2010 6:55 am
If you have a reversable drill, then you can buy reversed drill bits. I've had the broken bolt come out when I have been drilling the EZ out hole. Doesn't always work. I've also had a drill bit break in the hole and then your farked.
oldman
Users browsing this forum: No registered users and 17 guests
