mike-s wrote:You sure it wasn't the radiator fan? i know that every kawasaki bike i've had would run the fan after the ignition was turned off until it got below a certain threshhold.
robracer wrote:Turning off the ignition should cut any power supply to the fuel pump
Saki wrote:This might sound silly, but the high pitched whine, could have been pressure in your fuel tank coming out from where you fill it up.
mike-s wrote:or just open the fuel cap and see if you hear a sound like you just opened a pressure cooker perhaps?
